New Topic New Reply
Author: Subject: Locosts are rubbish.....
posted on 2/6/08 at 08:57 AM Reply With Quote
..... at off-roading.
I got stuck here!!>?!>!> WFT?
A slight slope, a teensy bit of mud and the back end was spinning!!!
PATHETIC!
But by rocking to and for managed to drive out or I would still be there! Rescued attachment stuck.jpg
mistergrumpy
posted on 2/6/08 at 09:00 AM Reply With Quote
It looks as though your front drivers side wheel is off the floor yet there seems to be no 'droop' in the suspension, as though the suspension is rigid. Is that right or am I seeing summat wrong?
omega0684
posted on 2/6/08 at 09:02 AM Reply With Quote
doesn't look like a locost to me, its a FORD! check out the badge on the bonnet.
posted on 2/6/08 at 09:42 AM Reply With Quote
Has it got any suspension on it?
Typically cars built for offroading have a lot of suspension travel - yours looks like it has little/none!!!
smart51
posted on 2/6/08 at 10:01 AM Reply With Quote
a limited slip diff would have helped. A picture of the front end doesn't let us diagnose your traction problems in your RWD car. As stated already, I would expect more suspension movement at the front.
posted on 2/6/08 at 10:27 AM Reply With Quote
I think the photo is a bit misleading - there is some droop but not a hooge amount as seen by the lifted front wheel - look at the distance between the coils on the front springs.
The light weight and road tyres don't help much either.
wilkingj
posted on 2/6/08 at 10:33 AM Reply With Quote
Damn... and just after I sold all my spare Land Rover wheels and tyres on Ebay.
I could have sold them to 02GF74
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 2/6/08 at 10:37 AM Reply With Quote
seems I am not the only one who has had trouble with a spot of mud
mr henderson
posted on 2/6/08 at 11:01 AM Reply With Quote
Well that's not very good, is it. Guy looks for a bit of sympathy and all he gets is a lecture about his front suspension not having enough travel (which I agree with BTW, but am much too shy to say so)
John
Ivan
posted on 2/6/08 at 11:33 AM Reply With Quote
They're also not much good for family holidays or as snow plows.
Anybody else know of anything else they're no good for.
ReMan
posted on 2/6/08 at 12:20 PM Reply With Quote
Fuel conservation
DaveFJ
posted on 2/6/08 at 12:29 PM Reply With Quote
Must admit - I had a spot of bother getting moving yesterday.. had parked on a gravel car park and as soon I touched the acellerator I showered the rest of the car park in gravel! (lucky no other cars in range!) had to pull away very gingerly! which is odd because so far I have been unable to get the wheels spinning on tarmac! (something to do wth the 245 wide rubber? )
[Edited on 2-6-08 by DaveFJ]
Dave
Triton
posted on 2/6/08 at 01:06 PM Reply With Quote
They don't float very well so no good for water skiing.......
www.tritonraceseats.com
www.hairyhedgehog.com
pjavon
posted on 2/6/08 at 02:45 PM Reply With Quote
Not the best for pulling into lay-bays with the women you love, especially with fibre glass race seats
Paul
Always keep a big hammer and a condom in your toolbox, if you can't fix it with the hammer
eznfrank
posted on 2/6/08 at 03:48 PM Reply With Quote
Ramraiding the local offy
b184
posted on 2/6/08 at 04:30 PM Reply With Quote
Not too good for the "big" shop at asda
Guinness
posted on 2/6/08 at 06:39 PM Reply With Quote
WTF! I guess someone towed the front off it!
Locosts, they're no good for moving house either.
Mike
Liam
posted on 3/6/08 at 12:12 AM Reply With Quote
Anyone knows 4 wheel drive is the only solution
posted on 3/6/08 at 03:44 PM Reply With Quote
Are you sure? (no, I am not volunteering)
Most have a PU sealed tub that is going to be quite watertight together with being lightweight and the bouyancy of the tyres it may well float, add an outboard engine and off you go.
Something for the Top Gear team to try out?
DIY Si
posted on 3/6/08 at 03:53 PM Reply With Quote
Mine seems to hold all the bloody rain in well enough, so it should be capable of holding out some water too. And no, I', not trying it either.
New Topic New Reply
