jacko
posted on 7/6/08 at 08:39 AM |
Fuel filter fitment on a corsa
Hi and good morning
what kind of job is it to fit the filter next to the tank it has some plastic clips on each end
corsa 1l 1998
Jacko
adithorp
posted on 7/6/08 at 11:42 AM |
Press the 2 clips in and pull. Some fuel will run out (so don't do it while smoking). Its just whats in the pipes and filter but it won't
siphon from the tank. Put your finger over the end when you pull the other end off to stop the filter draining completely untill your clear of the
car.
adrian
Dusty
posted on 7/6/08 at 11:43 AM |
Five minute job if you take your time. Connectors can be undone with pliers and there's one bolt. System is pressurised. Run engine until it
stalls after removing the fuel pump relay first.
[Edited on 7/6/08 by Dusty]
tks
posted on 7/6/08 at 03:37 PM |
3min job...like said above...
it really is a click a go jobby...
Tks
jacko
posted on 7/6/08 at 05:48 PM |
Job all done and finished thanks
Jacko
