scutter
posted on 7/6/08 at 10:16 AM |
More power please captain
After buying one of THESE batterys, i've found it a little lacking in the
cranking department, optimistic i know.
For around the same size does anyone know of a battery that will spin over a Zetec?
ATB Dan.
posted on 7/6/08 at 10:22 AM |
Ok, I have a Red Top 25 in mine which is about the same as yours and it spins the zetec over no problem.
I used throughout the build withoout an alternator and I've never had to charge it or seen it slow down.
Sure your wiring and starter are A OK??
stevebubs
posted on 7/6/08 at 10:28 AM |
I've a PC680 in my car (Zetec) and it's been faultless...
scutter
posted on 7/6/08 at 10:32 AM |
Wiring is the same as for the crossflow, starter is an unknown, i may test it on the bench.
Cheers, the redtop has a little more capacity than mine, mine will crank for 4-5 sec. then really slow down.
ATB Dan.
tks
posted on 7/6/08 at 10:38 AM |
ATB Dan.
if you get any heat in any wire then its capacity will slow down..
so it may look it is the battery but in fact it could be anything... do you notice a voltage drop..???
Tks
big_wasa
posted on 7/6/08 at 11:52 AM |
ive got one and it spins a freshly rebuilt 2L zetec over ?
Linc
You can just see it in above vid.
big_wasa
posted on 7/6/08 at 11:56 AM |
have you got good HD cables.
I was playing with a tiger loom for some one and the cable wasnt up to the job. It would crank 4~5 times then stop. And that was with a car battery.
Dusty
posted on 7/6/08 at 12:03 PM |
I have a pc545 that cranks my 2L raised comp zetec with no problem at all.
scutter
posted on 7/6/08 at 01:22 PM |
From what everyone has said, looking more like starter/flywheel woes. i'll just pop out and contect the 307 to the car and see if it's
any faster.
Cheers Dan.
Ivan
posted on 7/6/08 at 04:53 PM |
Does the engine spin OK with plugs out? If not then your problems are bigger than just starter/flywheel![](/images//smilies/sad.gif)
scutter
posted on 7/6/08 at 05:39 PM |
Ok, tested the starter system with from a jump start, same symptoms. Removed the starter and bench tested it with a Clarke 300 amp boost starter,
stun over but didn't seems particually quick.
When i removed it it was pressed against the alloy section of my sump and i'm wondering if i'd causted the body to twist out of alignment,
unlikely i know. looks like i'm after a wiring/poor earth problem.
I haven't tried removing all the plugs, just No.1, will try that in the morning.
ATB Dan.
