bigben
posted on 8/6/08 at 02:22 PM |
K-series spark
Hello,
Swapping the engine loom and ECU on my Ariel Atom back to the Rover original unit. Most stuff seems to work (starter, fuel etc) but don't have
any spark. Signals to coil I think are ok but need to borrow a scope tomorrow to check.
Any suggestions ? anyone near Cambridge willing to help for beer ?
Ben
stevec
posted on 8/6/08 at 02:30 PM |
Are the injectors triggering?
If not it may be a crank sensor fault.
If they are it may be a coil supply or coil fault.
Check all earths aswell.
Steve.
bigben
posted on 8/6/08 at 06:13 PM |
If the injectors were not triggering or the crank sensor not working would the ECU not trigger the coil ?
How would I know if the injectors are triggering ? They are wired up via a total lash up so are possibly suspect but don't see how the ECU
would detect this and not spark
Ben
posted on 8/6/08 at 08:01 PM |
Rover MEMS ecus are very picky -- even removing the flywheel and putting it back on or swapping the crank sensor can make the ECU need to relearn the
engines reluctor ring pattern.
First suspect however is as stevec says the cranksensor not unkown for them to go "iffy" after any major work is done such as a clutch
change.
bigben
posted on 8/6/08 at 11:13 PM |
Hopefully an oscilloscope will reveal everything tomorrow. Can check the crank sensor output and low side of coil pack
Ben
bigben
posted on 9/6/08 at 07:46 PM |
Crank sensor seems to be sensing the crank with a sensible waveform, not sure the coil is ok or not because I don't know what it should look
like, suspect it should have been oscillating more than it was.
I think if the crank sensor signal is not correct the ECU won't generate a spark so crank sensor is my prime suspect even tho its waveform
looked plausible.
Ben
posted on 10/6/08 at 09:12 PM |
On Rovers a lot depends on if the MEMS ECU thinks it has the OK signal from the security ECU.
The MEMS ECU, Security ECU and flywheel reluctor ring all have to be matched or the engine won't run.
