Kev99
posted on 8/6/08 at 03:53 PM |
Blade wont start when hot
Blade Very hard to start when hot ![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif)
Been ok for the last couple of years
Needs push starting most of the time![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif)
Any ideas where to start looking
[Edited on 8-6-08 by Kev99]
tks
posted on 8/6/08 at 03:57 PM |
Bump starting????
is it injection or carbs??
Paul TigerB6
Fuel evaporation maybe??
Kev99
posted on 8/6/08 at 04:01 PM |
Sorry should of said its an 893 carbed
running with everything as standard including air box
tks
posted on 8/6/08 at 04:23 PM |
mhh everything standard is not quet common on here i guess..
many times you need a rejet to adapt it to the air intake on the car.
running lean is bad for an engine..
check your plugs.../ clean the carbs...
Tks
worX
posted on 8/6/08 at 06:09 PM |
It's running a standard engine setup including standard airbox, so if anything it may be getting even less air than it did in the bike, so
running lean would prob not be an issue.
When it's hot have you tried to start it at full throttle?
Tks
Kev99
posted on 8/6/08 at 07:29 PM |
it some times starts on full throttle but not allways
i will have to have the carbs apart and clean them and change the plugs as tks says see if that helps
Kev..............
rf900rush
posted on 8/6/08 at 08:12 PM |
Hi
Had a simular problem on an old GSXR400 suzuki bike
New coils fixed it
No Idear why.
Needed to wait 30mins cool down be for start.
Strange thing was if I stalled it using the choke it would restart.
Very weird.
