Author: Subject: SVA form Q13
matt.c
posted on 10/6/08 at 07:29 PM Reply With Quote
SVA form Q13
How do i find out what to put into the sva form.
A: Maximum road speed?
B: Maximum power engine speed?
My car is a indy with ZX9r, 3.62 diff, 15inch wheels.
Im sorry if this has been asked before.
Opps! also how do i get proof of the engine age for Q17?
carlgeldard
posted on 10/6/08 at 07:37 PM Reply With Quote
Put about 125mph for max road speed. Have you got a manual for the engine it will till you max power in that. Proof of engine age send kawasaki uk an email with the engine number and they'll send you a letter. Max power I guess at 10500 but mines a 12 not a 9
Carl
snapper
posted on 10/6/08 at 07:38 PM Reply With Quote
Maximum road speed is so they can check you tyres are rated correctly. probably 110 to 120 with your gearing
Maximum engine bhp / revs is for the sound test so less is beter however these guys have a lot of experience and won't be fooled.
On a test i went to the tester said that the top speed on a Pinto engined 7 at 110 was unrealistic and increased it to 120
I eat to survive
I drink to forget
carlgeldard
posted on 10/6/08 at 07:39 PM Reply With Quote
Google found this mate
Max Power 143.00 HP (104.4 kW) at 11000 RPM
Carl
Snap-off
posted on 10/6/08 at 07:47 PM Reply With Quote
Hi Matt, you only have to prove the engine age if it is pre 95. They will test the car on the normal emissions tests if no proof is given.
matt.c
posted on 10/6/08 at 08:10 PM Reply With Quote
So if i put 120mph for the top speed and 140bhp for the engine power?
How does this affect the emissions?
Im crap at paperwork!
iank
posted on 10/6/08 at 08:16 PM Reply With Quote
Age of engine is the only thing that affects the emissions test. Post Aug 95 engine or one without proof = CAT test.
Top speed affects tyres you use.
120mph means you need U or better
http://www.blackcircles.com/general/speedrating
RPM you achieve max power (assuming 11000?) gives the sound test RPM - 8250rpm in your case.
[Edited on 10/6/08 by iank]
Anonymous
matt.c
posted on 10/6/08 at 08:20 PM Reply With Quote
So if i put 10000rpm, do you think they will be fooled?
mackei23b
posted on 10/6/08 at 08:23 PM Reply With Quote
Hi MAtt
I put:
A: Maximum road speed = 115mph
B: Maximum power engine speed =10,500 (Based on http://www.dynojet.com/pdf/2185.pdf)
C: Proof of age: I've got a letter from Kawasaki UK, see attachement, but it's still a CAT test.
Ian
[Edited on 10/6/08 by mackei23b]
eccsmk
for my zx12r i put 120mph
10,500 rpm
[Edited on 10/6/08 by eccsmk]
matt.c
posted on 10/6/08 at 08:32 PM Reply With Quote
Right then, thanks everyone.
Now on the V627/1 "Build up vehicle Inspection report" Paper.
Its all about the parts of the car ie chassis/axles/ transmision/engine etc and them having serial No's and receipts.
Because i bought my car as a part built i have no receipts for these parts. What do i do now?
iank
posted on 10/6/08 at 08:40 PM Reply With Quote
I'm sure you got the handwritten receipts as part of the part built package...
Anonymous
eccsmk
posted on 10/6/08 at 08:46 PM Reply With Quote
or the letter printed from the the flat lands owners club
think he was called matt.c or something
matt.c
posted on 10/6/08 at 08:55 PM Reply With Quote
Ahh! Thats the bloke
