Author: Subject: Padded Mountney Boss???
Jasper
posted on 4/12/03 at 07:27 PM Reply With Quote
Anybody got one they care to lend me for SVA???
Can use the Sierra steering wheel as it hits my gear stick.
bob
posted on 4/12/03 at 08:36 PM Reply With Quote
Jasper
Velcro a teddy on it,LOL
i'm going to stitch a piece of foam into a bit of offcut vinyl and velcro it on.
Brooky
posted on 4/12/03 at 10:09 PM Reply With Quote
i used some sticky back foam for the sva then it just fell off after.
paulf
posted on 4/12/03 at 10:22 PM Reply With Quote
I have fitted an escort xr3 wheel which is a lot smaller than a sierra wheel and even looks ok.
paul.
Jasper
posted on 5/12/03 at 10:24 AM Reply With Quote
Cheers Chaps, think I will go for the stick on foam.....
BTW - Got my chassis number through today - that was remarkably quick and easy, my local DVLA are really on the ball and helpful.
posted on 5/12/03 at 10:37 AM Reply With Quote
One concern - if you look at the bit about steering in the SVA manual it talks about the wheel/steering column system, which has to be regarded as a whole.
I know it's paranoid, but it's one reason why I'll be going to the SVA with the original wheel. I know yours collides with the gearchange, but didn't the Sierra come with various size wheels (depending on whether you had power steering or not)? Can't you find a smaller one in a scrappy?
Also, 'stick-on foam' goes right against the grain of the description in the new manual (see 'SVA update' thread). I know that version isn't in use yet, but those changes are only the new rulings made official. There is one part that says that all padding must be similar to what a manufacturer would fit, i.e. not taped-on foam.
Might be worth talking to the test centre!
rds,
DJ
Spyderman
posted on 5/12/03 at 11:39 AM Reply With Quote
rds,
DJ
Surely YOU are the manufacturer, and as long as it is "E" marked, is padded, it should be OK!
It's possible that it is refering to imports and is not too clear.
Just a thought!
Terry
Spyderman
timf
posted on 5/12/03 at 01:23 PM Reply With Quote
spoke to the sva tester at lunch (just up the road) they wont accept covers that are tapeed on anymore but if the padding is velcroed on they will ie the cover velcros to its self.
hope this helps
Northy
posted on 5/12/03 at 06:44 PM Reply With Quote
Jasper,
I've got one if you need to borrow it
Graham
RoadkillUK
posted on 5/12/03 at 06:57 PM Reply With Quote
Could I borrow it around April/May time
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Jasper
posted on 5/12/03 at 09:25 PM Reply With Quote
Thanks Northy, I'll send you a U2U nearer the time if thats ok, should be beginning of Feb
Northy
posted on 5/12/03 at 10:12 PM Reply With Quote
No worries Jasper
I'll only need it for one day (or two if I need a retest)
I also have some indicator extensions (Thanks Matt)
And I hoping to buy an exhaust insert tommorrow to reduce the noise
All available to borrow for SVA's, beer tokens accepted to cover postage
Graham
zetec
posted on 5/12/03 at 10:41 PM Reply With Quote
I've just got my pad back from a bloke who used it for his SVA, also a grill I got from Lolocost as I knew the MK one would not pass, fits the MK nose just right with 4 cable ties.
As with Northy can post off if need be.
Northy
posted on 5/12/03 at 10:44 PM Reply With Quote
Well Zetec, looks like you've got the southern half of the country covered, and I'll do the northern half
Also got a standard Sierra steering wheel somewhere
Graham
theconrodkid
posted on 5/12/03 at 10:49 PM Reply With Quote
ive got a padded bra if anyone wants to use it
who cares who wins
pass the pork pies
steve m
posted on 5/12/03 at 11:37 PM Reply With Quote
Northy
Dont buy an exhaust reducer, as I have got one that i never used if I can find it !
If i find it i can send it on for anyone else to use
all it was is two tubes welded inside of each other
or just use a piece of tube that will fit inside of your exhaust and weld a large washer in front of it so all of the gas has to go thru a smaller hole
I believe that the smaller the hole the less noise
It will play havoc with the performance and fuel economy
but an sva pass is the ticket
