rich201283
posted on 4/12/03 at 11:33 PM |
engine change
is a 2.0 pinto the same physicle size as the 1.8 pinto and are the carbs in the same place if u can get the with carbs as standard?
theconrodkid
posted on 4/12/03 at 11:48 PM |
same size and all mounting and bolt holes in the same place
who cares who wins
pass the pork pies
PeetBee
posted on 5/12/03 at 10:57 AM |
straight swap, but does the air filter come through the bonnet?
If so then it's possible that the pierburg carb on your 1.8 would be in a slightly different place to a weber carb meaning you'd have to
reshape the hole in the bonnet.
