rich201283
posted on 5/12/03 at 10:14 AM |
will fitting 2.0 carbs to my 1.8 pierberg carbed pinto make much difference in power?
PeetBee
posted on 5/12/03 at 10:54 AM |
Don't know anything about the pireburg carbs, but you would need to retune the 2.0 carb to suit the 1.8 or at worst get it rejetted.
Is this the problem as I thought it was the gearing that was wrong with your car?
posted on 5/12/03 at 01:24 PM |
The one to go for would be a 32/36 DGAV from an early car but you will need the manifold as well. It would improve your engine but the ordinary
30/34DFTH would be an improvement over the Pierburg.
yours, Pete.
stephen_gusterson
posted on 5/12/03 at 02:01 PM |
you keep asking this question, and I dont think you are understanding the basic nature of carburation.
you could also fit carbs from a 3.5 rover, and thats even better! But its not!
there is an ideal mix ratio (summat like 14:1) of air to fuel by weight, and thats what you need to have the carb tuned to deliver.
a bigger carb, with the right jets for your engine, will only give more power if the whole engine 'flows' better, from inlet manifold to
exhaust.
fitting std 2.0 carbs to a 1.8 will almost certainy make the car run rich, be less powerfull, and cost more to run.
atb
steve
[Edited on 5/12/03 by stephen_gusterson]
paulbeyer
posted on 5/12/03 at 03:35 PM |
yours, Pete.
I've got one I haven't got round to selling yet. recondition kit and new spindle fitted, all sat on a fine looking Pinto inlet manifold.
You could always make me an offer before I try tempting the Robin Hood boys.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
posted on 6/12/03 at 12:19 AM |
The pierburg you have is single choke. The ones you are looking at will be twin choke webers. You may have to do some jet swapping but the way to find
out is by trying one. I don't think the 1.8 was made with a twin choke but the 2.0 should get you in the ball park, you can experiment from
there.
yours, Pete.
