Author: Subject: Speed - Hole saw
kango
posted on 16/6/08 at 08:27 AM Reply With Quote
Speed - Hole saw
What speed should I set my drill to when using a 25mm hole saw?
bilbo
posted on 16/6/08 at 08:30 AM Reply With Quote
This may be of use:
http://www.aonx97.dsl.pipex.com/WS-page/table-page/tables.htm#Drilling
Edited to say DOH! - should read your post better. Talking about hole saws, not drills.
Here:
http://www.fairburyfastener.com/holesaw_speed_chart.htm
[Edited on 16/6/08 by bilbo]
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
posted on 16/6/08 at 08:56 AM Reply With Quote
Another good tip someone (Andy donut I think) put up a while back was to swap the drill for a piece of solid bar same diameter once your centre hole is through. It gives much better more solid location.
Mr Whippy
posted on 16/6/08 at 09:05 AM Reply With Quote
as above, makes a world of difference, especially drilling grp. Though just use a normal drill on its own to make the guide hole rather than change the cutter over.
posted on 16/6/08 at 10:34 AM Reply With Quote
Yup. Much easier to replace the drill bit in the hole saw with a bit of rod then just drill a normal hole with a bit of the same size and swap the bit to the hole cutter.
For GRP you can go pretty damn quick with a hole saw If it starts smoking slow down a bit before you do the full Ray Mears impression.....
kango
posted on 16/6/08 at 11:19 AM Reply With Quote
Thanks, I an making "A" arms.
What is the best way to index the pipe at the same plane - if I have drilled though the one side and set it up to drill the orher side that the 2 holes are going to be at the same angle. A bit difficult to explain, but if you made them before you will know what I mean.
Fred W B
posted on 16/6/08 at 01:11 PM Reply With Quote
Hi Kango
Lay the pipe in a piece of angle and use the edge of the angle to draw a straight line down the pipe with a marker
Fred W B
liam.mccaffrey
posted on 16/6/08 at 02:39 PM Reply With Quote
i have set my lathe up to do exactly this sort of thing,
Build Blog
Build Photo Album
kango
posted on 16/6/08 at 04:59 PM Reply With Quote
Like your new Avatar Fred W B
The 90 deg cut went ok at 350 rps. The 38 Deg cut destroyed my brand new hole saw. So it is back to gring and fitting. Unfortunately no lathe.
