Author: Subject: testing vr sensor
omega0684
posted on 18/6/08 at 11:49 AM Reply With Quote
testing vr sensor
how can you test whether or not the vr sensor is giving off a pulse?
theconrodkid
posted on 18/6/08 at 01:20 PM Reply With Quote
wave a screwdriver over the end,you should get 0.5 volts ac
who cares who wins
pass the pork pies
posted on 18/6/08 at 01:41 PM Reply With Quote
Plug the input into a cheap amp and spin whatever you're testing up.
As long as you're getting more than 20 pulses per second you should hear something..... Interference might be an issue though....
clairetoo
posted on 18/6/08 at 04:32 PM Reply With Quote
Everything you ever wanted to know about megasquirt is here
Although it can be hard work finding the answers
Its cuz I is blond , innit
Claire xx
Will weld for food......
tks
posted on 18/6/08 at 05:47 PM Reply With Quote
measure the resistance if isn't there it wont work..
yupsz an AC voltage swing should be visible...
don't untherestimate the voltage...it really can go high...
Tks
