paulmw
posted on 19/6/08 at 12:02 PM |
Gear Number Indicator
As I cant count I reckon I would benefit from a gear number indicator display
What have people used. I pressume it is a simple plug and play?
Paul
nitram38
posted on 19/6/08 at 12:07 PM |
For Bec's, yes
eddbaz
posted on 19/6/08 at 12:45 PM |
The gipro is one of the best on the market
Jubal
posted on 19/6/08 at 12:47 PM |
I drove a BEC with a display on it earlier this week. It was useful and as a result I've been investigating and pricing them up. The Acumen DG8
seems to be the easiest for my engine but I think you are a bit too cutting edge for a plug and go loom. They go for about 75 all in on ebay but the
best info is on the manufacturer's website.
http://www.acumen-electronics.co.uk/
You could always wire the generic one in as per these instructions.
http://www.acumen-electronics.co.uk/pub/files/User%20Guides%20etc%20-%20PDF_s/1197905466_Acumen%20DG8%20.pdf
[Edited on 19/6/08 by Jubal]
russbost
posted on 19/6/08 at 01:15 PM |
The Acewell 3250 (amongst it's many other features) has a gear indicator that works with any engine. As I understand it the computer works out
the revs/speed 7 therefore what gear.
Why pay loads of money for a gear indicator when you can have all the rest as well for pretty much the same money?
Paul TigerB6
posted on 19/6/08 at 01:32 PM |
I'm planning on using the GIPro on my own car with the ZX10R clocks as Paul is using on his. Not sure if the ZX10R restricts the engine in the
lower gears for which the TRE is used to disable but would be interested to find out.
li
nky to ebay
tegwin
posted on 19/6/08 at 01:33 PM |
It cant be too hard to make one....
Get a 7 seg display, two microswitches (one for up and one for down) and some circuitry to do the thinking...
Only issue would be keeping the number callibrated with the actual gear when you turn the electronincs off and change gear, but wouldnt be hard to
figure it out...
I recon you could make one for around £6....infact, Im making some PCBs this week...might have a go at designing and manufacturing a gear
indicator...
www.verticalhorizonsmedia.tv
nitram38
posted on 19/6/08 at 01:51 PM |
Russ, although I have a Veypor dash with gear indicator, I also have the Accumen as it is a nice bright led display.
I think trying to look at an lcd readout will be a bit more difficult as per the acewell.
tks
posted on 19/6/08 at 03:37 PM |
figure it out...
indicator...
yupsz... use an input from neutral to reset it...
Tks
nitram38
posted on 19/6/08 at 03:44 PM |
figure it out...
indicator...
Tks
But don't you pass through neutral on the way to second?
loggyboy
posted on 19/6/08 at 03:58 PM |
Datatool do one that seems quite straight forward.
2 versions, one for manual speedo, one for electronic.
It simply works on speed and engine revs, comparing the 2 figures to calculate the gear your in.
Manual version uses wheel (or i assume they could be driveshaft/abs ring) mounted sensors to pick up the speed. where as the elec one picks up the
signals being produced by the standard speedo sensor.
posted on 19/6/08 at 05:22 PM |
figure it out...
indicator...
If you have a look at my website, that's exactly what I did. Cheap as chips. Microswitches, a feed of the neutral light and a £1 PIC....
posted on 19/6/08 at 05:25 PM |
http://website.lineone.net/~btbromilow/first.htm
is the link to the description. I designed it for my brothers Blackbird Fury. Works well once the microswitches are set up.
Personally I don't bother with one, if I'm not sure what gear it's in I just give it another tug and see what happens ie when I run
out of gears I stop changing up ![](/images//smilies/wink.gif)
Mark G
posted on 19/6/08 at 06:01 PM |
I just ordered the Acumen DG8 off ebay, its waiting for me to go and collect it in the post office as we speak.
Delivered for less than £50 for a new one, I thought was a pretty good price.
iank
posted on 19/6/08 at 06:15 PM |
There was a project (pic based) in the Jan 06 copy of EPE for one based on the rpm vs speed style.
http://www.epemag.com/magindex.html
[Edited on 19/6/08 by iank]
Anonymous
PAUL FISHER
posted on 19/6/08 at 06:45 PM |
Ive got the gpro on my zx10r,plug and play,it also got the built in retard iliminator,which you can switch on and off at the push of a switch,it also
has hard and soft settings,it can help when its wet,sort of a simple traction control.
bigrich
posted on 19/6/08 at 07:44 PM |
Another GI pro here, and yes the TRE works well giving a much quicker pick up in the lower gears.
