Author: Subject: Idiots Guide to Wiring Cars?
Slater
posted on 19/6/08 at 02:55 PM Reply With Quote
Afternoon, I am about to start installing my Premier Wiring loom. I am a total beginner at car electrics. Can anyone recomend a book or website which explains the basic car wiring principles in laymans terms with simple diagrams.
I see terms like switched live or switched earth, what they mean? Also how do relays work?, where should the fuses go in the circuit? etc. I just need some basic knowledge to get me started.
Over to you.
Keith.
Mr Whippy
posted on 19/6/08 at 03:02 PM Reply With Quote
haynes do a car electics book that is quite good. This one infact -
http://www.bizrate.com/transportationbooks/haynes-automotive-electrical-manual--pid681094156/compareprices__keyword--michael+haynes.html
I have had it for years and is worth reading before you do the wiring. I is not too techinal and easy to read and follow. You should find it in Halfords, any probems you have just ask on this site.
[Edited on 19/6/08 by Mr Whippy]
tks
posted on 19/6/08 at 03:21 PM Reply With Quote
a fuse will be as short to the battery placed...
its the only securance which keeps the car from burning down.
i mount 3 main fuses at 100mm from the battery plus terminal..
Switched....
because of the fact that you have a positive and a negative lead you can cut each of them to make the needed connection to a light or horn or etc...
a relais is easy to google and you will find everything from there..
Tks
Mr Whippy
posted on 19/6/08 at 03:27 PM Reply With Quote
If possible I think a battery cut off switch, even on a road going car is a great idea and worth fitting. They also look very cool.
Macbeast
posted on 19/6/08 at 03:31 PM Reply With Quote
The premier wiring loom should come with ready wired fuses. In addition, as tks says, you should have a "fusible link" - just a fuse - 40 to 80 amps between the battery and anything on your loom (but not the lead from the battery to the starter which will take more than 80 amps. Vehicle Wiring Products 0115 930 5454 do fusible links amongst many other electric things.
Complete Kit Car has been running a 3-part electrics feature (May June and July)
which deals with some of the basics.
mookaloid
posted on 19/6/08 at 04:25 PM Reply With Quote
The Premier Loom comes with instructions, which, if you follow them to the letter will result in a working loom. Alan at Premier is a great help if you get stuck too
Mark
