Author: Subject: How to cover this for SVA?
Snap-off
posted on 24/6/08 at 01:12 PM Reply With Quote
Hi Guys,
Any suggestions welcomed for ideas on how to cover the headlight bolt and nut for SVA.
I intended to crop it and use a plastic nut cover with a hole but the nut is 5/8'' and I can only find metric nut covers
headlights for sale
headlights for sale
JeffHs
posted on 24/6/08 at 01:20 PM Reply With Quote
I couldn't find a cover to fit the nuts on my botttom ball joint so I used a small cover on the exposed thread and a grommet stretched round the hexagon.
Mr SVA failed me on all sorts of other things but seemed happy with that.
Guinness
posted on 24/6/08 at 01:21 PM Reply With Quote
I slotted a metric nut cover that was about the right size, made a hole in the end for the cable to come out, then wrapped the lot in some black electrical tape to about 1" down the conduit.
HTH
Mike
Agriv8
posted on 24/6/08 at 01:24 PM Reply With Quote
Rubber foot from an old dears walking stick.
Regards
Agriv8
Snap-off
posted on 24/6/08 at 01:33 PM Reply With Quote
Thanks guys,
Some good ideas for me to think about.
Steven.
jabbahutt
posted on 24/6/08 at 01:49 PM Reply With Quote
what about the rubber boot things that go over the nut and gubbins on a junction box?
They sell them in B&Q and come in different sizes. You could cut the end off to allow fitment and then use a tie wrap
Sorry the gubbins is called a gland and apparently the bit I'm thinking of is a gland boot.
Might help, hope it does.
Nigel
smart51
posted on 24/6/08 at 01:58 PM Reply With Quote
I cut a large nut cover so I could get it round the bolt without removing the wire and stuck it on with a blob of PU. They are still there 3 years on.
richardh
posted on 24/6/08 at 01:59 PM Reply With Quote
i did the immediate above with black silicone sealant
posted on 24/6/08 at 02:00 PM Reply With Quote
I have just the job here, I'll send a pic when i get home later.
U2 me your address and I'll post a couple out.
designer
posted on 24/6/08 at 03:13 PM Reply With Quote
Why not just shorten it?
posted on 24/6/08 at 04:44 PM Reply With Quote
These are what i've used
I chopped mine down slightly because I removed a bit of the thread on the headlamp. Can easily be trimmed to size. Cut a hole in the nipple end for the wiring.
Sorted!
Snap-off
posted on 24/6/08 at 05:09 PM Reply With Quote
Excellent! Just the job!
tks
posted on 24/6/08 at 08:34 PM Reply With Quote
what is it..??
i need 2 of them to..
