Author: Subject: R1 tilt switch
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 24/6/08 at 05:23 PM Reply With Quote
R1 tilt switch
Anyone know where to drill the tilt switch to pump it full of goop. Don't want to drill in the wrong place and firk it up.
adithorp
posted on 24/6/08 at 05:56 PM Reply With Quote
Pop the sensor out of its casing (2 little pips hold it in. Stick the little pendulum in the centre of its swing. Let it set. Then slot it back in.
I drilled mine and squeezed stuff in but it moved the pendulum. I stripped it, cleaned it out, stuck it and shoved it back wet and it moved. Thats why I say let it dry.
adrian
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
Will it work ok like that then Chris. ??
Originally posted by chris mason
no idea where to drill it, but why not leave it as Yamaha intended, you'll have less hassle that way.
Chris
andy o
posted on 24/6/08 at 06:00 PM Reply With Quote
mine is as standard,no probs
worX
It'll probably cut the engine if you roll it in a ditch until you push it back over again, so if that's the sort of thing you are trying to avoid then stick it...
Actually in all seriousness, I've secured all the ones in looms I've built in much the same manner as Adithorpe. Dismantle glue pendulum in place and re-assemble.
Chris
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 24/6/08 at 06:01 PM Reply With Quote
Adi
Now wheres that lovely sikaflex
Daimo_45
posted on 24/6/08 at 09:05 PM Reply With Quote
I went out in car with tilt sensor and it shut the engine on a hard corner so glue it.
tks
posted on 24/6/08 at 09:42 PM Reply With Quote
or just join the wires.... (take it out)
its what i could do on my VFR 800 from 1998..
Tks
worX
posted on 24/6/08 at 10:18 PM Reply With Quote
Thats not always possible TKS, sometimes that would be possible to cause more headaches than solve them, so although it would be ok for one bike, beware that it's not always the best advice for all bikes...
Tks
