Author: Subject: single phase motors
eccsmk
posted on 25/6/08 at 04:18 PM Reply With Quote
single phase motors
ive borrowed a cement mixer with the wrong motor on it
its turning the wrong way is there any way to get the motor to spin in the opposite direction??
thanks folks
tks
posted on 25/6/08 at 04:34 PM Reply With Quote
single phase..???
mhhh....
normally a single phase engine only uses 2 windings and a third which is only enabled on startup...
the 2nd winding uses an capacitor...tu generate an offset on the normal wave shape..
google is your friend i would say...
Tks
Wadders
posted on 25/6/08 at 04:38 PM Reply With Quote
As you apply power, give it a helping hand in the right direction.
Alternatively try plugging it in to a neighbours supply. My old next door neighbour had a wood lathe that ran in opposite directions when plugged into his/my supply. weird but true.
Al.
thanks folks
eccsmk
posted on 25/6/08 at 04:42 PM Reply With Quote
thank you
found a couple of decent articles on the subject
eccsmk
posted on 25/6/08 at 04:56 PM Reply With Quote
Al.
thanks folks
wierdly the owner says it works for him
but i doesnt work for my nieghbours
r1_pete
posted on 25/6/08 at 05:00 PM Reply With Quote
If you take the cover off the motor, where the wire goes in, there is usually a connections diagram to wire it for CW or CCW rotation.
eccsmk
posted on 25/6/08 at 07:16 PM Reply With Quote
i thank you kindly
