Author: Subject: Head lights
Razor
posted on 26/6/08 at 06:58 PM Reply With Quote
Head lights
May sound like a daft question, but what are the size requirments for front head lights, ive seen some 4 inch head lights but would these be ok as most ppl have 5 and 3 quaters?
richardh
posted on 26/6/08 at 07:32 PM Reply With Quote
cant see why not
as long as the beam is of righ power wattage etc ....................
i saw a 7 type with some oblong ones about 3 inches tall ........................
iank
posted on 26/6/08 at 07:40 PM Reply With Quote
4" are motorbike lights and aren't guaranteed to pass SVA as they dip straight. Though Russbost has a mod that may let them pass assuming the tester doesn't require the correct arrow mark for left dip.
Do a search it's been talked to death.
Anonymous
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 27/6/08 at 02:35 AM Reply With Quote
yup i modded mine my own way and passed no probs. took 5 mins to do.
Hammerhead
posted on 27/6/08 at 09:49 AM Reply With Quote
care to share what you did?
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 27/6/08 at 09:39 PM Reply With Quote
there is a small nodule on the bottom of the lens which keeps the lens and dip pattern straight and flat. This little nodule needs to be gotton rid of, i used a dremmel, and then the lens can be rotated by around 3-4 degrees so that the beam points to the left. Done
