Author: Subject: Changing i Pod batteries
trextr7monkey
posted on 1/7/08 at 06:32 AM Reply With Quote
Any tips?,daughter's battery has died and she has prudently nipped out and bought a replacement, nice to see such faith
Reading the instructions it all seems clear but there could be a trick!
Anyone got any tips other than being very careful?
cheers
Mike
hughpinder
posted on 1/7/08 at 06:37 AM Reply With Quote
I did mine and two other peoples(all series4 ipods) - I used 2 stanley knife blades to slip between the joint and carefully levered away. Work round gradually or you may put a kink in the case.
Regards
Hugh
givemethebighammer
posted on 1/7/08 at 06:59 AM Reply With Quote
Load of links if you google "change ipod battery"
i.e.
http://lifehacker.com/software/ipod/how-to-replace-your-ipods-battery-236138.php
Did mine a while back, I used a thin plastic guitar pick to open the clips
[Edited on 1/7/08 by givemethebighammer]
Mr Whippy
posted on 1/7/08 at 07:36 AM Reply With Quote
just be gentle as it is easy to mark the sides
tricker than it looks on you-tube
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 1/7/08 at 11:49 AM Reply With Quote
i did mine once, what a nighmare, and it ended up the ipod itself was kaput and not just the battery
trextr7monkey
posted on 1/7/08 at 10:54 PM Reply With Quote
Cheers job done, new battery fully charged.
The video was useful, also little plastic tools that came with battery, presume the big warnings are so people can't complain if they do mess up
atb
Mike
