Author: Subject: Anyone work for BT?
ChrisW
posted on 9/7/08 at 05:15 PM Reply With Quote
Anyone work for BT?
As subject really!
Bit of background first:
Having loads of problems with my phone line, not that I ever use it for calls. I'm less than half a mile from the exchange, but I get really bad ADSL speeds, and every time someone rings the landline (which just has a fax machine on it) the ADSL connection hangs.
All my voice calls, both for the business and personal, go out via VoIP. However, if I plug a regular phone into the line, it crackles away like a bonfire.
I've tried all the obvious stuff (yes, I do have a reasonable amount of technical knowledge on the subject, having owned an ADSL ISP for a while!), new microfilters, test socket, blah blah blah.
I've discovered that the line into the block of appartments is aluminium, and it's a rather convoluted route to get to my flat - goes through a master drop point, then to a slave, also connected via aluminium. I've run a new (copper) cable from my flat down to the sub drop box which improved things slightly. I also tried punching a socket directly into the main drop box, and it was even better (but still not great) but obviously I can't leave the router sat in the corridor outside someone else's flat, nor run Ethernet from there up to my flat.
Now, here's the question! I'm told BT will replace aluminium cabling if you can get hold of the right person to report it to. Apparently there are "SPI's", special premises investigators, that can decide that it really is aluminium and make arrangements to have copper installed instead. However, nobody seems to be able to put me in touch with one of these people.
So... any BT, or ex-BT people... who do I need to call to get hold of one of these SPI people? Or, what can I say to customer services to get them to put me through?
Cheers, Chris
[Edited on 7/9/2008 by ChrisW]
speedyxjs
posted on 9/7/08 at 05:28 PM Reply With Quote
Youl need to take about a week off in order to have engough time to get through to them!
phoenix70
posted on 9/7/08 at 05:43 PM Reply With Quote
Cheers, Chris
Hi Chris,
Not sure of changing to Copper will make that much on a difference, but if you hear a lot of crackling on the line when a normal phone is plugged, then you should be able to get BT to fix it and hopefully that will also resolve your ADSL problem. If there is a high level of noise on the line then report it as a fault and they should come out and fix it.
P.S. I've got a similar problem with my ADSL but mine is down to being miles away from my exchange.
Scott
Jackman
posted on 9/7/08 at 06:12 PM Reply With Quote
Once you have taken the week of and got though dont forget you cant speak to them in english as they dont understand you!
GOOD LUCK!
splitrivet
posted on 9/7/08 at 06:37 PM Reply With Quote
Im an independant Telecoms engineer Chris and could write a book on how bad BT are getting.
Changing to copper wont make any difference.
It sounds like you have an underground fault or a bad connection in a DP somewhere en route. Go to the first box in your premises if you have extensions undo the 2 screws holding the lower half of the faceplate the lower half will then unplug any extensions will be wired to the rear of this lower half. Plug your handset into the socket thats now revealed via a Broadband filter if it still crackles its definately the line, ring faults (154 from a business line) do it between 9 to 5 otherwise youll get the call centre in India and let them hear it crackle. This way you'll stand a good chance of getting it sorted, if your with an alternative provider or its a domestic line god help you.
Ive just spent since Monday morning trying to get a BT engineer to switch a clients lines back on who moved premises 100 yds. BT finally got his line working at 4 PM today and we are still waiting for his Fax/Broadband the job was appointed for last Friday.
This is not a one off every job we have done that involves BT over the last 12 months has given us similar hassles.
If your fax is a Hewlett Packard try disconnecting it, I seem to remember having problems with these and B/B
Bob
[Edited on 9/7/08 by splitrivet]
posted on 9/7/08 at 06:44 PM Reply With Quote
I had a load of hassles with BT over a line problem - mostly due to the incompetence of their contractors. I kept a note of every call I made (there were many). Eventually I called Oftel and complained: they gave me a reference number and an Ipswich telephone number - when I rang I found out that it was the local service manager, who was NOT impressed when he read the history of the problem. The phone was fixed within a few days.
I'm not saying that this is the answer for you, but you never know...
stevebubs
posted on 9/7/08 at 06:48 PM Reply With Quote
Chris,
As per David's recommendation, if you've persued it via BT without success, I'd raise with OfCom - you'll be surprised how fast BT can work if they want to.
Stephen
(ex CW)
ChrisW
posted on 15/7/08 at 10:41 PM Reply With Quote
Update! According to BE:
The monitoring of your phone line has identified a possible problem with the physical connection of your phone line to the broadband equipment of Be* Unlimited at the exchange or an issue on the medium itself. It is necessary to arrange the re-connection of your phone line first, and in case the disconnections of your service persist to check the last mile copper that runs to your premises. The re-termination of the line is a task that can take several working days to be accomplished and requires an engineer to be sent on site. During this process you are going to experience a network downtime.
Any ex-BT people tell me whether it will really take 2-3 days of downtime to replace the connection? Surely it's just a case of going to the Krone frame and putting a new patch in?
Chris
Macbeast
posted on 16/7/08 at 05:07 AM Reply With Quote
If they have to check the last mile of copper ?
They're probably giving you the worst-case scenario to cover themselves. And it doesn't actually say that you are going to be disconnected for the entire period of the investigation, just that you will experience downtime.
ChrisW
posted on 17/7/08 at 12:33 AM Reply With Quote
Well, that's what I thought. So I asked exactly that... and was told 2-3 days downtime.
Not sure whether to just put up with it. All the business stuff goes through the line - half a dozen VoIP lines, VPN for Exchange server, all our network monitoring.... 3 days downtime would be an absolute nightmare.
I've got an HSDPA router around somewhere which would do most of it, but I can't see the phones being too happy over that kind of connection!
Chris
JamJah
posted on 17/7/08 at 11:24 AM Reply With Quote
some routers will show you how many packets need to be resent. if it noise on the line affecting your broadband youll have a high number.
but i guess you know that.
This is personal advise or personal opinion.
Constructive comments gratefully recieved, picking is left for noses.
