Author: Subject: Light Positioning
ahb
posted on 12/7/08 at 09:07 PM Reply With Quote
Light Positioning
I want to put indicator, stop/tail and fog on rear arch. For SVA and to keep 10cm between fog and stop/tail, is it OK to mount (from left to right) stop/tail-indicator-fog fog-indicator-stop/tail. That is with the indicator in the centre?
Hello!
omega 24 v6
posted on 12/7/08 at 09:45 PM Reply With Quote
It's not a problem AFAIK BUT you must still have a maximum of 400mm from the outer edge of the vehicle to the sidelight OR the Indicator which ever is farthest in. Also I'm thinking you must have very wide wings for everything to fit.
ETA that remeber it's 100mm from the edge of the light emmiting surface not the lamp centres.
[Edited on 12/7/08 by omega 24 v6]
ahb
posted on 13/7/08 at 07:35 AM Reply With Quote
Thanks for that. Just standard MK wings. Diameter of lights 70mm. SO 3 times 70 plus 4 times 20mm spacing equals wing width.
Hello!
