Author: Subject: testing fuses
bracey
posted on 14/7/08 at 09:11 PM Reply With Quote
testing fuses
been looking at my fuses ,and have the usual spade ones and a relay one and some cube like ones ??
how do you test the cube like ones??
cheers
bracey
(a relay fuse )and would one of these be used on the ignition??
[Edited on 14/7/08 by bracey]
Image deleted by owner
Macbeast
posted on 14/7/08 at 09:15 PM Reply With Quote
Pic ?
Howlor
posted on 14/7/08 at 09:18 PM Reply With Quote
You should have about 8 normal spade fuses and probably 5 cube relays and a flasher unit for the hazzards/indicators.
posted on 14/7/08 at 09:49 PM Reply With Quote
LOL - cube fuses .....
those are relays or flasher unit.
easy to test - you would apply 12 V and listen to them clicking or measure resistance between contact.
they will have numbers like 30, 86, 87a, 88 .. which luckily for you conform to a standard.
what they mean look here
Howlor
posted on 15/7/08 at 08:18 AM Reply With Quote
One (relay) may be used on the ignition but not definate. There is normally a fuse for ignition live though so it may be that. What is your problem and I will try to help talk you through what to check?
bracey
posted on 15/7/08 at 05:34 PM Reply With Quote
swapping from manta engine to xe and now wont turn over and battery light does not light up why i thought fuse??
Howlor
posted on 15/7/08 at 07:45 PM Reply With Quote
What wiring have you done in the swap over? Have you kept the injection on the XE engine?
I did this swap for my brother in law on a Manta 400 so know it well.
