COREdevelopments
posted on 14/7/08 at 09:46 PM |
koso speedo
hi all. as some of you may know already my car failed on the speedo. i am using a koso rx1n and thought i had set it up correctly, however it is way
off.
the tester gave me a print out of the speedo test.
it is as follows
Actual speed-------speedo speed
speed 1 008mph----------------35
speed 2 009 --------------------40
speed 3 011 --------------------50
speed 4 013 ------------------- 60
speed 5 014 --------------------70
now what have i done wrong? im using 195/50/15 tyres and entered a circumference of 1810mm and am using 4 magnets. i think my diff is 4.3:1. also the
pick up is mounted on the prop. has anyone else used this type of speedo with it mounted on the prop? got my retest week tommorow.
any ideas guys?
atb
rob
[Edited on 14/7/08 by COREdevelopments]
austin man
posted on 14/7/08 at 10:10 PM |
when we set up the brother in laws electronic speedo we kept passing one of those speed detectors and adjusting the value until it matched, looks like
its the circumference you have a problem with. Our startin point was based upon 2000 rpm with a car engine with a 5 speed box was between 40 and 50
mph do we jacked up the back end and got the car to the required rpm then checked the speed aginst this and adjusted then took it out on the road, the
SVA tester should let u recalibrate the speedo
austin man
posted on 14/7/08 at 10:12 PM |
we mounted the sensors on the driveshaft ie after the diff
vorn
posted on 15/7/08 at 01:53 AM |
looking at those numbers I would say you need to divide the number you put into the Koso by 4 .
That would make it alot closer !
Vorn
theconrodkid
posted on 15/7/08 at 06:06 AM |
i had similar probs with mine,managed 225 mph on the jack,take 2 magnets off and go from there ,in top 40 mph should be about 2000 rpm as a starting
point
who cares who wins
pass the pork pies
COREdevelopments
posted on 15/7/08 at 06:53 AM |
dividing by 4 sounds like a good idea Vorn, i will try that and see what readings i get.
thanks
rob
richardh
posted on 15/7/08 at 06:54 AM |
nope
the kos has a minimum circumference of 3ocm thus putting it on the prop and telling it that the wheels are 1810 will put it way out.
either put it in thr front upright and mount the magnet (1) on the hub or similar.
or find somewhere that will be more than 30cm in circumference and change the 1810 to that measurement
easy job - i know as i had to change mine (pre sva luckily)
if you are using an r1 engine then be aware that the revs will be off if you set the pistons to 4 and the cylinders to 4 ...............
i had to play about with mine - thankfully i ride one so i could do a side by side check.
i'm still awaiting the actual resolutiojn to that problem from KOSO europe
russbost
posted on 15/7/08 at 08:10 AM |
You need to divide by your diff ratio of 4.3 surely because your on the prop not a driveshaft?
cloudy
posted on 15/7/08 at 10:06 AM |
your values appear to be about 4.3 out - so multiply the circumference by 4.3 before entering. if this value is too large you can set it to 2 magnets,
which will double your reading then adjust circumference to suit.
Richard - the circumference is NOT a minimum of 30cm - mine works just fine on output shaft about 7cm across. Rememeber the magnets pass at the same
interval no matter the size of the object it's mounted to.
www.warnercars.com
vorn
posted on 15/7/08 at 08:36 PM |
"russbot" the diff ratio has to do with it .
mark the ground and wheel with chalk
roll the car one rev of the wheel and mark the ground again
measure between the marks ( this is the number to put into the speedo unit)
if you have more than one magnet , divide the measurment by the amount of magnets ( someone said the Koso has a setting for the amount of magnets , if
so don't divide the number )
the unit is looking for how far the car travels between each pulse from the magnets.
Vaughan
[Edited on 15/7/08 by vorn]
COREdevelopments
posted on 22/7/08 at 07:40 PM |
and the correct answer is as russbot said, i divided the circumference by the diff ratio, which was 1810 divided by 4.3 which was 420.93 so put in 421
with 4 magnets and hey presto my speedo is almost spot on,
70 is 1 mph below
40 is 2 mph below
but thats good enough for me and the sva man
hope this helps anyone
rob
[Edited on 24/7/08 by COREdevelopments]
