<<  1    2  >>
Author: Subject: Leaded and unleaded (may sound stupid)
speedyxjs
posted on 15/7/08 at 07:25 PM Reply With Quote
This has confused me. I ordered a reprinted manual for my new old mg midget and it says it should be filled up with 97 RON 4 star.
Can i run it on 97 RON unleaded?
[Edited on 15-7-08 by speedyxjs]
Mr Whippy
posted on 15/7/08 at 07:28 PM Reply With Quote
yes it’s the same, it will be fine.
neilj37
posted on 15/7/08 at 07:32 PM Reply With Quote
97 RON is super unleaded rather than the regular unleaded which is 91 RON
[Edited on 15/7/08 by neilj37]
Howlor
posted on 15/7/08 at 07:34 PM Reply With Quote
The only difference I presume is that you will burn through the valve seats without the lead additive.
mr henderson
posted on 15/7/08 at 07:35 PM Reply With Quote
Only if you don't mind the valve seats getting all f*cked up. You need to get harder valve seats fitted
John
Damn it, must type faster
[Edited on 15/7/08 by mr henderson]
speedyxjs
posted on 15/7/08 at 07:37 PM Reply With Quote
thats what i thought. I meant to add without adding additive
blakep82
posted on 15/7/08 at 07:43 PM Reply With Quote
i heard years ago that old engines that were running leaded petrol for years and years were ok to run unleaded for a while as they built up enough lead deposit in the fuel system to be safe, but how long for (and if its true) i don't know.
________________________
Howlor
posted on 15/7/08 at 07:56 PM Reply With Quote
There are those things you drop in the tank that are supposed to do the same job as the lead.
trogdor
posted on 15/7/08 at 07:57 PM Reply With Quote
if you keep the revs down and don't do many miles you will prob get away with it.
But i think this is going to be your daily driver?
You can buy lead additives that will help but you prob be better getting the heads modified.
GeorgeM
posted on 15/7/08 at 07:58 PM Reply With Quote
I run my frogeye on unleaded with an additive.
Other solution is a metro head
GeorgeM
posted on 15/7/08 at 08:13 PM Reply With Quote
GeorgeM
1500 ?? IIRC So Metro head is no good?
DRC INDY 7
posted on 15/7/08 at 08:21 PM Reply With Quote
castrol valvemaster + and it does work ive used it for years in many a classic car
plus i will be useing it in my indy
Puddle Dodgers Club
mr henderson
posted on 15/7/08 at 08:22 PM Reply With Quote
GeorgeM
1275 Metro
iank
posted on 15/7/08 at 08:30 PM Reply With Quote
Midget had two engines during its life
1961-1974 Chrome bumpers had A-series in 948, 1098 or 1275cc
1974-1980 Rubber bumpers had a 1500 Triumph spitfire engine (complete with chocolate crank).
Anonymous
posted on 15/7/08 at 09:09 PM Reply With Quote
GeorgeM
1275 Metro
Rubber bumper Midgets were NEVER fitted with the A series engine so a 1275 Metro head will not fit. Uses the same engine as the Triumph Spitfire
dhutch
posted on 15/7/08 at 09:13 PM Reply With Quote
Dont know anything about other engines, but in landrover circles the consensus seams to be to run it with a splash of addative, which will proberbly be fine. And if its not then the valve seated needed doing anyway!
Daniel
posted on 15/7/08 at 09:17 PM Reply With Quote
Yes in the short term -- but this engine is likely to have used up all its leaded memory effect years ago.
Also if it is a 1275 A engine they are notorious for burning exhaust valves in the centre pair of cylinders.
posted on 15/7/08 at 09:23 PM Reply With Quote
Nothing to do with revs but a lot to do with the end gas temperature in the cylinder --- ie wide throttle opening. Also a weak mixture or retarded timing will overheat the valves.
posted on 15/7/08 at 09:24 PM Reply With Quote
No the only good they do is to the sellers bank balance.
posted on 15/7/08 at 09:29 PM Reply With Quote
GeorgeM
1275 Metro
True Never factory fitted --- a lot have been fitted with ex-Marina engines over the years.
Fatgadget
posted on 15/7/08 at 09:48 PM Reply With Quote
Out of interest has anyone actually experienced burnt out valve seats first hand through running low ron fuel?
andyps
posted on 15/7/08 at 10:42 PM Reply With Quote
It isn't the RON which is the problem for valve seat recession, it is the lead. Shell Optimax or Tesco 99 will still get recesssion in a car designed for lead. The lower RON will just mean it may pink under load and won't develop as much power as it should.
The Castrol lead additive is very cheap in overall terms and worth using as LRP is becoming very hard to get hold of now. Don't know how much genuine 4 star is if you happen to find somewhere selling it.
If running unleaded when it should be leaded the important thing is to avoid steady throttle openings for prolonged periods - that is what burns the seats away so motorway runs are the worst.
Paul TigerB6
posted on 16/7/08 at 12:16 AM Reply With Quote
It better had work - otherwise i spent 4 months wasting my time evaluating the production process for production over here for the UK market!!!
smart51
posted on 16/7/08 at 07:02 AM Reply With Quote
The lowest grade sold in the UK is 95 RON.
speedyxjs
posted on 16/7/08 at 07:03 AM Reply With Quote
Cheers guys
Iv got some castrol valvemaster and used that when i came back after picking it up so il just keep using that.
<<  1    2  >>
