Author: Subject: This one's got me
speedyxjs
posted on 16/7/08 at 08:11 PM Reply With Quote
This one's got me
The old throttle cable on my midget was very stiff - as if it was rusty - so i replaced it. Only today have i been able to take it for a spin with the new one. It was fine for about 4 - 5 miles then the new one started to get very stiff. I managed to get home on the choke (made interesting driving )
The pedal itself is fine and the carb end also operates smoothly when operated by hand so i dont know what else to do.
Any idea's?
Fatboy Dave
posted on 16/7/08 at 08:15 PM Reply With Quote
Check the engine earths, this is an old one. Usually the earth strap corrodes and the throttle/choke cable become the new earts and promptly melt.
Failing that, check to see if you have any tight bends or kinks in the cable.
Dave
Stop the planet, I want to get off
gavin174
put a jag engine in it!!!!!
(sorry couldn't resist)
theconrodkid
posted on 16/7/08 at 08:17 PM Reply With Quote
engine earth lead not doing its job and melting the cable?is it nylon lined?
who cares who wins
pass the pork pies
speedyxjs
posted on 16/7/08 at 08:18 PM Reply With Quote
Hmmm, interesting. No tight bends (that was my first suspition)
[Edited on 16-7-08 by speedyxjs]
MkIndy7
posted on 16/7/08 at 08:30 PM Reply With Quote
has the outer of the cable come loose from whatever it braces against and both cables are moving?
so when you were pressing the pedal you were just trying to pull both inner and outer sleve through the bulkehad rather than 1 inside the other.. that would also give you little or no throttle to get home on.
iank
posted on 16/7/08 at 08:58 PM Reply With Quote
If it started ok but got stiff then it's probably an engine earth problem.
Anonymous
mark chandler
posted on 16/7/08 at 11:09 PM Reply With Quote
Alternatively if it goes close to the exhaust and has a nylon/plastic liner they can melt, in which case you want a cheap cable!
