New Topic New Reply
Author: Subject: c20xe redtop exhaust manifold
donn006
posted on 20/7/08 at 12:51 PM Reply With Quote
hi any one outhere know whare i can get a exhaust manifold make or even still has any one got a spare for sale im in the northants area
stevepj
posted on 20/7/08 at 05:08 PM Reply With Quote
you could always make your own if you have the standard manifold
cut the manifold just below the 4 into 2 joints, turn the bottom section thru 180 degrees and cut most of the length out of the two pipes, weld back together and then weld on 90 degree bend to point it to the rear
this is on my robin hood, you can see the top of the manifold and where it exits the body
New Topic New Reply
