Author: Subject: MK Standing quarter at barkston heath
phil T5
posted on 23/7/08 at 10:07 AM Reply With Quote
have a look at my first attempt
about 12.5 secs
http://www.youtube.com/watch?v=x6ZhGtY2QkI
Kriss
posted on 23/7/08 at 10:11 AM Reply With Quote
good time. what engine and set up are u running? cant see the vid at work
phil T5
posted on 23/7/08 at 10:30 AM Reply With Quote
Its a vauxhall XE thats done by QED that came with car. Its about 235hp and around 180ft/lbs. I think at santa pod or somewhere with some grip it should get in the 11's
I had issues with rear suspension though, it was my first track day
see
http://www.locostbuilders.co.uk/viewthread.php?tid=93810
oldtimer
posted on 23/7/08 at 12:12 PM Reply With Quote
Looked nice and quick, but, as you say, there are issues - I can't believe that all that straight line movement was torque effect with a live axle??...
froggy
posted on 23/7/08 at 08:07 PM Reply With Quote
none too shabby but i doubt you go a lot faster if you get more traction .12.5 is pretty damn good though.did you get your 60ft and 1/8th times too?
phil T5
posted on 23/7/08 at 09:11 PM Reply With Quote
only got standing 1/4 times.
did 2 timed runs best of 12.4 but its slightly uphill at end and it was pretty dusty and bumpy so hoping could get in 11s? who knows.
terminal speed only 102mph which is a bit diappointing expected more.
Once suspension sorted its York or santa pod rung what you brung I think
froggy
posted on 23/7/08 at 09:34 PM Reply With Quote
you might get a few tenths at the pod but your terminals are not far off for that power and weight. it takes some practice to get off the line .if you try and control your launch and compare your 60ft times with a flat out start .i gained 3 tenths by stopping it spinning in first but my terminals were only a couple of mph different.i would reckon on a low 12 with 110 terminal if you hook it up and launch well.its pretty addicitve though
york is ok if you are near to it but i was 0.6 slower 0-60 there but ran the same et as the pod but with a slightly slower terminal speed .most people are dissapointed with the times to start with but a 12.5 is enough to see off most cars on the road
[Edited on 093131p://3914 by froggy]
procomp
posted on 24/7/08 at 08:02 AM Reply With Quote
Hi a good live axle setup with 200hp Should be able to get the 60ft times down to 1.9sec.
After watching the vid i would get the alighnment of the axle checked for being square in the car along with the other checks in the other thread. Looks to be steering from the rear causing the change of direction.
