a_j_mair
posted on 25/7/08 at 08:22 PM |
what determines reg of kit car
thought they all went on Q plates unless you used X% of donor car
how do you get it on an 08 plate?
dave1888
posted on 25/7/08 at 08:29 PM |
You can get a new reg if all the parts are New with the exeption of 1 component which can be refurbished beware you will have to provide all relevent
receipts and invoices.
a_j_mair
posted on 25/7/08 at 08:32 PM |
so all new parts, does that include all suspension hubs etc new engine the lot?
how much is one component? seems grey area to me
r1 locost
posted on 25/7/08 at 08:45 PM |
its not that gray it's more black and white one major recon part the rest new or just build it with all new parts keep your recipts and hay
presto one new plate o8 at the moment...
adithorp
posted on 25/7/08 at 08:53 PM |
For a new reg' all major components must be new with the exception of one which must be reconditioned as new.
The form your supplied with to declare the parts lists, Chassis, Engine , Transmission, Axles, Streering, Suspension, Body. It requires
manufacturer, ID number and reciept for each.
You also have to sign a declaration of newness.
adrian
mangogrooveworkshop
posted on 25/7/08 at 11:02 PM |
but the downside of a new registration will be the emissions and gordys evil tax...
Q just gets a visual check.....good if you are bec powered
graememk
posted on 26/7/08 at 07:59 AM |
i dont get this new thing..... i wanted a Q plate
TOO BADD
posted on 26/7/08 at 09:45 AM |
Got an 03 reg and no emissions test. Pre 95 engine recon'd to new
posted on 26/7/08 at 10:17 AM |
I wanted a Q plate too. And I got it
The regs on when you do and don't get a Q plate, age related or new plate are pretty clear but most of the local DVLA offices are a bit ditsy
about knowing when to apply which rule....
posted on 26/7/08 at 12:43 PM |
Ive got an 08 plate but the emmisions is based on the engine being made in Feb 1994. Recon engine and everything else new
paul the 6th
posted on 10/8/08 at 08:28 PM |
i quite like the idea of being one of the first '09-ers but i probably couldn't afford to recon an engine as well as all new bits for
everything else...
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
