Blue Fox
posted on 28/7/08 at 10:42 AM |
Harness help
Are these budget harness from rallydesign SVA ok?
http://www.rallydesign.co.uk/product_info.php?cPath=66_68&products_id=289
Also how has everyone fitted the mount for the top fitting? I was thinking I could weld another peice of box paralel to the current rear bar betwwen
the suspension plates and plate that. Would that be ok for SVA and practical or does anyone else have a better idea?
Mr Whippy
posted on 28/7/08 at 11:02 AM |
Harnesses are fine as is your proposed mounting method but you may find that the mounting point is too low for the SVA requirements, if ok then use
3mm plate and weld a captive nut to the underside of the plate (use the correct thread)
[Edited on 28/7/08 by Mr Whippy]
Blue Fox
posted on 28/7/08 at 11:09 AM |
Hello,
Yeah I though about it possibly being too low and thought if I welded the additional bar and plate on and it turned out to be too low then I could
weld a vertical plate on the front bar and gusset plate from the new vertical plate which the harness will be bolted to down to the new bar and plate
to give it the strength. Would this be ok.
Mr Whippy
posted on 28/7/08 at 11:25 AM |
Have you thought about a roll bar? Most folk fit them as they make a lot of sense. You can then run a tube across and use that to mount the harness. I
think you'd be best just having a look through peoples photo archive and seeing what others have done. Check the SVA height requirements first
before doing anything, best to do it right the first time.
here is the SVA requirement -
![](/galpreviews/annex4a.JPG) ![annex4](/gallery/annex4a.JPG) annex4
