Gremlin
posted on 11/7/02 at 03:50 PM |
Has anyone ever thought of galvanising there chassis?
Any input good bad idea!
theconrodkid
posted on 11/7/02 at 04:45 PM |
bit expensive and as its done hot there is a chance of distorting the chassis
Jon Ison
posted on 11/7/02 at 04:59 PM |
Don't you have to drill a hole in all the tubes too ? or is that just BZP plating........to let cleaning acid out ? ![](/images//smilies/wink.gif)
Fatboy Dave
posted on 11/7/02 at 06:55 PM |
Jon,
Certainly do. That's why it's not a good idea. Also, you can buckle it if you have welded in steel floors (once saw a Land Rover bulkhead that had
been galvanised. Bugger had warped through 90 degrees).
It also adds a fair bit to the weight too....
Dave
Stop the planet, I want to get off
Jon Ison
posted on 11/7/02 at 08:28 PM |
thought so, we have a fair bit of plating done at work, but its all BZP, no holes = mess. funny how my engine mounts found there way into the tank ???
Gremlin
posted on 11/7/02 at 11:53 PM |
Ok thanks. Best not try that then!
Alan B
posted on 12/7/02 at 02:37 PM |
quote: funny how my engine mounts found there way into the tank ???
Yeah, don't you hate it when that happens
And when your own personal drawings somehow end up going through the machine shop and get made accidently, that's a bugger too ![](/images//smilies/bigsmile.gif)
merlin
posted on 12/7/02 at 07:35 PM |
It was suggested to me by a local company specializing in restoring old classics that the best result would be to Zinc Phosphate the chassis and then
powdercoat it. Quite what zinc phosphate is I have no idea but my chassis looks pretty damn good!
shit happens! (but why always to me!!)
Gremlin
posted on 14/7/02 at 10:28 PM |
Sounds good but how much does the zinc and powder coat cost ruffly?
Fatboy Dave
posted on 14/7/02 at 10:33 PM |
quote: It was suggested to me by a local company specializing in restoring old classics that the best result would be to Zinc Phosphate the chassis
and then powdercoat it.
Isn't that like the paint-on galvy stuff, like Galvafroid?
Waste of time if you ask me (powder coating over this stuff). Either just powder coat it, or get it scrupulously clean and use chassis black enamel
like you get on wagon chassis'
Dave
Alan B
posted on 15/7/02 at 02:01 AM |
Guys,
I have worked with several powder coaters over the last 20 years, including some guys who, at the time, had the contract for TVR, and from their
combined wisdom I would say that phosphating is a fairly standard pre-treatment for higher quality/more demanding powder coating work. I would expect
any chassis or any outdoors components to be phosphated prior to coating and that many good coaters would not even not mention doing it, because it is
such normal procedure. I think it is basically a kind of etching primer.
It certainly isn't a waste of time, and adds little extra to the cost.
Hope that clarfies things ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif)
Alan B
posted on 15/7/02 at 02:23 AM |
Guys,
I just got this off the web, if you're interested:
"What is phosphating and why do I need it?
The generic term "phosphating" is a process where an acid attacks the metal of the work piece and re-deposits a material that is a combination of
the metal substrate (and other metals - like zinc) along with phosphate. This process creates a surface that is tightly adherent to the base metal,
has more surface area, provides improved corrosion inhibition, and helps the powder coating stick better. It provides a good coating base so the
finished part has increased usable life."
