Author: Subject: Keihin carburettors
westf27
posted on 31/7/08 at 05:52 PM Reply With Quote
Keihin carburettors
Zrx 1200 carbs..does the adjustable pilot jet underneath richen or weaken the mixture as you unscrew it
whitestu
posted on 31/7/08 at 05:54 PM Reply With Quote
On my Mikunis I was working under the impression that unscrewing weakens the mixture as it is an airscrew. I suspect most bike carbs are the same.
I could be wrong though.
bigrich
posted on 31/7/08 at 05:55 PM Reply With Quote
almost all bike carbs richen as you unscrew the mixture screw,
You now have a dilema LOL
[Edited on 31/7/08 by bigrich]
posted on 31/7/08 at 06:02 PM Reply With Quote
Yup. Richens as you unscrew. More fuel
westf27
posted on 31/7/08 at 06:06 PM Reply With Quote
http://www.ooracing.com/tuningTips.htm#mainjet
have just read this and it gets rich as you screw it in ??
mistergrumpy
posted on 31/7/08 at 06:25 PM Reply With Quote
My ZX9 Keihin carbs get richer as you screw it in. Checked with Haynes manual and that says the same.
takumi
posted on 31/7/08 at 08:34 PM Reply With Quote
on my Keihin carbs (cvk40 i think) screwing in makes it lean,
unscrewing makes richens it.
the screw is the final control on the idle fuel circuit.
Just had to screw it all the was in to pass my MOT emissions, way under the limits..
Half a turn out sounds alot nicer.!
posted on 31/7/08 at 09:19 PM Reply With Quote
Unscrewing leads more air in leaning it off. It only affects idle and a little bit above it.
At SVA my HC was over 1200 and unscrewing the needles dropped it down.
Roman
posted on 1/8/08 at 02:00 PM Reply With Quote
Not sure but this site may help.
Look near the bottom of the page.
