Poll: Another - Which Welder
Clarke 150 TE Turbo 4 (0%) -»
Clarke 151 TE Turbo 6 (0%) -»
Clarke 160 T Turbo 5 (0%) -»
Author: Subject: Another - Which Welder
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 9/8/08 at 12:54 PM Reply With Quote
I've done afair bit of research ovr the last few days loking at budget welders.
I've searched here and on http://www.mig-welding.co.uk both of which have given masses of info.
I'm now pretty sure i will be getting a Clarke welder as these seem to have pretty good press.
I am going to need the welder for a car transport trailer that i want to make for the MK. I may also use it for restoring old cars, welding fences, gates general bits and bobs!
I have got my choice down to 3 welders as follows:
Clarke 150 TE Turbo - £199.69
Clarke 151 TE Turbo - £223.19
the only adv of the 151 over the 150 it seems is an easy access door to change the wire? And it is in a red case?
Both of these welders are in the hobby range
In the prof range there is the
Clarke 160 T Turbo - £234.94
This seems not to be able to weld quite as thick metal (seems strange?) and i can't see anything else that bumps the price up a bit?
I'm not sure the difference between T and TE??
Any help with picking one out of these three?
CraigJ
posted on 9/8/08 at 01:33 PM Reply With Quote
Ive got a 151, bought it second hand and never had a problem with it. ideal for use on the kit car.
matt_claydon
posted on 9/8/08 at 01:44 PM Reply With Quote
I believe the 160T comes with a regulator for big bottles whereas the 151TE takes 'hobby' bottles. Not sure about the 150TE.
Re welding gates etc, they say they'll weld 5mm but 3mm is probably more realistic. There's a good article on mig-welding about hobby welder capability.
MikeR
posted on 9/8/08 at 01:50 PM Reply With Quote
i've got a 150, from my perspective its a great welder. I got mine VAT Free from machine mart when they had an offer on.
I think the 160 with the 'professional' torch means a torch with a 'euro' connector. If it does you can change the torch if needed in future without scrapping the welder.
Reality is 150 does most people but you'll need to build a trolley to move it around. Spend as much as you can afford and you prob won't regret it. (the diff between 150 and 151 is nothing - ask in the shops and they're likely to say the same so you're really looking at 150 or 160)
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 9/8/08 at 02:05 PM Reply With Quote
just thought i should say these prices are from my 2006 catalogue, there are a bit more expensive now.
looks like it is really going to be between the 150 and 151... due to price increases
[Edited on 9/8/08 by iscmatt]
MikeR
posted on 9/8/08 at 02:46 PM Reply With Quote
do you have to buy now? Machine mart do VAT free days around 3 or 4 times a year.
(or they used to, haven't seen one for a while)
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 9/8/08 at 02:51 PM Reply With Quote
no, not right this minute, anybody have an idea when the next no VAT day is?
MakeEverything
posted on 9/8/08 at 03:07 PM Reply With Quote
For £200 you could buy a TIG welder, Gas, Regulator and filler metal and end up with neater welds, and a nice tan....
I recently bought one from Germany on ebay for £140, and i love it. You can weld (not structurally) without any filler metal, and even with the welds are fantastic. Its easier to set up, too.
Im running on tiny little hobby gas bottles at £10 a piece at the moment, but im hoping to get an Argon Cylinder soon...
Kindest Regards,
Richard.
Mansfield
posted on 9/8/08 at 04:30 PM Reply With Quote
Around here (and most other areas too I believe) there is normally one at mid to end of October. I seem to remember one around April also.
The 150 and 151 look to have identical guts so I guess it is down to colour. I have just looked on line and the 150 is 99p cheaper, that might be enough to swing it for you.
I would have the 151, I think it looks more modern if you ever wanted to sell it.
MikeR
posted on 9/8/08 at 09:19 PM Reply With Quote
if you're thinking of tig you do get nicer welds but .... TIG is less forgiving of the set up - ie you can have a less than perfect gap between the two lumps of metal with MIG and get away with it.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 9/8/08 at 10:35 PM Reply With Quote
no, i'm getting a mig for now, thanks.
posted on 10/8/08 at 09:26 AM Reply With Quote
Nobody sees them as they are hidden under the bodywork
rodriguez
posted on 10/8/08 at 01:16 PM Reply With Quote
i bought a 160T about 2 years ago. was 234 quid then and does come with the adapter for big bottles. I use it constantly and have never had any bother at all. I was like you and was considering the 151 at 1st, but having used both i would recommend spending slightly extra and get the 160
get it lit
eccsmk
posted on 10/8/08 at 01:28 PM Reply With Quote
here you go
i havent read the thread so might be completely useless
[Edited on 10/8/08 by eccsmk]
aerosam
posted on 10/8/08 at 03:08 PM Reply With Quote
Second vote for TIG, also that I need to upgrade to a large argon bottle as my hobby argon cylinders just don't last.
djmnr
posted on 17/8/08 at 07:13 PM Reply With Quote
i got a 205te and very happy.. good value imo
mad-butcher
posted on 17/8/08 at 08:02 PM Reply With Quote
have a look at recontooloing on ebay this guy handles sealey's returns reasonable prices normally has 1 or 2 of the commercial sets having said that i've got a 150te not a bad machine
tony
