Shamrock GS
posted on 10/8/08 at 11:12 AM |
Weber air adjustment query
On a set of twin 45s how do you adjust the air intake to balance the carbs.
I have the flowmeter set up and can take the readings but my detailed instructions then say; ' adjust the balance mechanism between the
carbs' and I am not clear what that is.
Idiot proof guide please
Gary
[Edited on 10/8/08 by Shamrock GS]
Sun Tzu, The Art of War
SeaBass
posted on 10/8/08 at 11:24 AM |
The section on Dave Andrews site is very good at explaining this...
Look under Setting the Idle and slow running
Here
Hows the rebuild going?
Are you working on the car today? - I fancy a blast out somewhere...
[Edited on 10/8/08 by SeaBass]
Shamrock GS
posted on 10/8/08 at 07:10 PM |
Have u2u contact number
Car back in action. Using older bonnet (damaged in an earlier but less damaging fire!) and everything more of less cleaned up.
Got a pair of twin webers from a friend locally so after taking the head off to remove melted fibreglass and extinguisher powder, I'm back to
primitive technology. The interesting thing is that with different jets than before the thing goes much better. It was almost worth having the fire
(almost),
Gary
posted on 11/8/08 at 10:52 AM |
your carbs -did you say weber or dellorto? - will look similar to these (dellorto).
In the middle you see the balance adjsuter - above hte blue pipe - that joins the two carbs. It is spring loaded and has a screw.
You tweak the idle on one carb then tweak the ajduster screw; I do it by ear until the exhasut note is even.
you may find the idle changes so you need to adjust that again.
Idle screw in photo is just above the choke cable close to the throttle cable end piece.
[img][/img]
