Author: Subject: Rear wing protectors
posted on 10/8/08 at 04:17 PM Reply With Quote
Got myself a sheet of black abs sheet with a slightly naff (but fortunately, almost invisible) carbonfibre pattern on it. This is going to be cut into 2 wing protectors, so now I have 2 questions:
1. Once I've got my card template sorted, what's the best way to cut this stuff? It's about 2.5mm thick.
2. Does it sand down nicely to give a good edge finish?
ok - 3 questions!
3. What's the best way to fasten it to the wings? Pop rivets? nuts and bolts? (BTW: I hate self-tappers)
cheers,
MkII
posted on 10/8/08 at 04:28 PM Reply With Quote
my wing protectors are fixed using small(m4 IIRC) stainless countersunk bolts & nuts. cant help with the abs sheet sorry ive never used it.
worX
posted on 10/8/08 at 04:29 PM Reply With Quote
1. It cuts nice with a hacksaw IMO - I've got a Half hacksaw blade in an old stanley knife for tight corners
2. It sounds down OK - just use a block with paper wrapped round it for uniform finish.
3. You could use adhesive for a clean look or just use Black 5mm Rivets.
[Edited on 10/8/08 by worX]
fesycresy
posted on 10/8/08 at 04:35 PM Reply With Quote
Aviation / tin snips work a treat.
MakeEverything
posted on 10/8/08 at 04:37 PM Reply With Quote
Id do the same. Id cut it with a Jigsaw or hacksaw, then file it with a fine file, and dress with wet 'n' dry for a perfect finish. Id glue it on with PU glue tool
Kindest Regards,
Richard.
chrisj
posted on 10/8/08 at 05:44 PM Reply With Quote
If its too thick/brittle for tin snips you can try and cut it with a jigsaw on a slow speed (too high and it will melt the sheet) using a sacrificial bed of styrofoam underneath it. It stays flat and the blade goes straight through both materials easily.
posted on 10/8/08 at 08:17 PM Reply With Quote
We've just sanded the dges of our carbon-fibre trims (the tiny threads of CF dont half stick in lovely soft pink skin!!) - they are secured using double-sided body moulding tape. Flexible, can be removed and replaced (unlike PU) with a little effort.
posted on 10/8/08 at 08:25 PM Reply With Quote
Steve,
Is that double-sided tape easy to find? For example, I know a good car painting supply place - is it the sort of stuff they'd sell?
Also - any brand names I can quote?
P.S. my stuff is pretend c-f finish on abs - so fibres are not a problem!
posted on 11/8/08 at 10:29 AM Reply With Quote
i use M4 stainless steel button heads.
start at one side and drill holes working to the other side so that the protector sits flush agasint the wing.
arch protectors
arch protectors
Black Cat
posted on 11/8/08 at 07:36 PM Reply With Quote
A band saw is the best way to cut it, it won't chip and gives a very smooth finish, then sand with wet and dry.
Don't stick it as you will at some point need to remove it.
