New Topic New Reply
Author: Subject: Exhaust manifold heat shield...
scoop
posted on 14/8/08 at 11:30 AM Reply With Quote
Is Ali too soft for the job or should i use stainless instead? It will be bolted to the mani' itself.
Steve.
JAG
posted on 14/8/08 at 11:53 AM Reply With Quote
I've used Aluminium, it was fine.
engine with exhaust heat shield
[Edited on 14/8/08 by JAG]
Justin
pewe
posted on 14/8/08 at 11:59 AM Reply With Quote
I've used some soffit board from the local builders merchant - used to be asbestos but is now some fire-resistant stuff and it's cheapish! Secured to two of the manifold pipes using some large diam. spring tool clips.
Seems to work OK on the small amount of running I've done idling on the drive - at least the clutch cable's still unmelted!
Can take a pic or two in interested.
Cheers, Pewe
scoop
posted on 14/8/08 at 12:05 PM Reply With Quote
The reason i ask is because i have loads of ali' lying about but no stainless
Humbug
posted on 14/8/08 at 12:21 PM Reply With Quote
I've used ali bent to fit, secured at one end with tabs on the manifold bolts and the main part fixed with an exhasut clamp to one of the pipes. Been there for a while with no apparent problems.
[Edited on 14.08.2008 by Humbug]
JAG
posted on 14/8/08 at 12:47 PM Reply With Quote
On my car (in the picture I posted) the heat shield has three legs rivetted to it, each leg is about 50mm long. The ends of the legs are 'L' shaped and rest on the manifold pipes.
Then a jubilee clip was passed around the manifold pipe and the end of the leg pushed under it and the clamp tightened up.
The black tube running across it is the wiring loom in black corrugated tubing and this has not melted in the 7000 miles I've covered to date.
Justin
Mix
posted on 14/8/08 at 03:40 PM Reply With Quote
Hi
Alloy will be fine as long as it can be supported adequately to prevent work hardening and subsequent cracking.
Regards Mick
Shamrock GS
posted on 14/8/08 at 05:15 PM Reply With Quote
I stuck heat resistant , reflective blanket to the underside of the bonnet. Never had any problems and my exhaust exits over the top of the chassis rail so is much closer to the bonnet itself.
Gary
Sun Tzu, The Art of War
scoop
posted on 15/8/08 at 09:31 AM Reply With Quote
Many thanks. Ill use the ali' ive got then but go for the thicker stuff.
Ta, Steve.
New Topic New Reply
