andyw7de
posted on 14/8/08 at 03:36 PM |
Paddle Shift
Ive just cut a paddle shift template and was wondering if these would be of any interest to all you BEC boys out there.
The pic is really only as an idea i can cut anything into the shifter eg engine logo,(ZX) or car type (MK Indy) (GTS) etc
I would be looking to cut from 6mm Aluminium which can then be powder coated if required
PM me if your interested
worX
posted on 14/8/08 at 04:04 PM |
Do you have ideas of Dimensions and costs?
LBMEFM
posted on 14/8/08 at 08:45 PM |
Really interested, ball park figure please for a surround for the hole in the side panel where the exhaust exits, and a handbrake ring for the tunnel.
I am sure other members would be interested too.
[Edited on 14/8/08 by LBMEFM]
andyw7de
posted on 14/8/08 at 09:30 PM |
Overall diameter is 320mm but can be tweeked to any size required.
If i were cutting a couple then the price would be £20 delivered, can get this down a bit if the quantity were to be higher.
As and example if i were to cut 10 or more then i could do these for about £15
cheers
andyw7de
posted on 14/8/08 at 09:37 PM |
If as an example the suround were to be cut from 3mm Aluminium then your probably looking at around £3 - £4 each again probably cheaper for 10 or
more
Stainless steel ones would be more expensive
We could get really fancy and cut a ferrari type 'H' gate type gear lever suround
SJL
posted on 14/8/08 at 09:56 PM |
Put me down for a paddle shift and handbrake surround in black please.
Need to check the dimensions first though
