Author: Subject: granada bottom ball joints
leggin
posted on 27/12/03 at 04:04 PM Reply With Quote
has any builder used the granada front hub yet if so which ball joint fits i know a astra 1 does not
James
posted on 28/12/03 at 12:18 AM Reply With Quote
The Granada BJ hole is different from the Sierra? Weird...
If you've definately tried all the Astra options then AFAIK all you've got open to you is to pay someone like Luego or MK to bore the hole out to fit a Cortina one.
Or, you could of course get hold of a tapered drill bit and build a jig and do it yourself!
MK did mine for £7 per side.
Bearing in mind that the Granada uprights are 5 stud (so you'll have difficulty buying nice alloys- if you're into that) and that Sierra equivalents are so cheap is it worth the effort?
HTH,
James
leggin
posted on 29/12/03 at 11:14 PM Reply With Quote
if u use a granny ghia you get 15 alloys + a twin cam engine , remote gear linkage and an irs
James
posted on 2/1/04 at 02:39 PM Reply With Quote
Well, they certainly are lovely alloys! And from what people on here have said it's an engine to look out for.
As regards the IRS- bear in mind the Granada track is 1" wider than the Sierra.
All in all I wish I'd used a Granada myself!
James
stephen_gusterson
posted on 2/1/04 at 08:23 PM Reply With Quote
I did
beware abs adding complexity if you keep it....
atb
flash git
leggin
posted on 3/1/04 at 07:11 PM Reply With Quote
+1 inch is nothing iv added 4 inches to the irs
