saigonij
posted on 17/8/08 at 12:24 PM |
Gear Lever surround - can someone make it please
Can someone make this for me please? out of 3-4mm ali. I will pay for it.
It needs a bend in the middle - which is why i need it made.
Ian.
posted on 17/8/08 at 12:36 PM |
If you want a crisp bend then you'll need quite thin material.
It sounds like a perfect job for Water Jetting Scotland!!!
Ask them to make it out of thin ali (3mm if that's minimum) and stick it in a vice.... Voila...
Humbug
posted on 17/8/08 at 12:44 PM |
Not too difficult to make it yourself if you've got a jigsaw
saigonij
posted on 17/8/08 at 12:53 PM |
i want it to look professional - which is why i dont want to make it myself!!!!!
Who are Water Jetting Scotland?
posted on 17/8/08 at 12:55 PM |
andyw7de on this list is water jet scotland
http://www.waterjetscotland.co.uk/
saigonij
posted on 17/8/08 at 12:59 PM |
just sent them an email.
have you used them before?
indykid
posted on 17/8/08 at 01:26 PM |
you currently have the radii on the corners the same on the inside and outside.
it might be worth specifying it with concentric radii to tidy it up a little if you're having it water jetted.
imho of course
tom
andyw7de
posted on 17/8/08 at 02:03 PM |
Hi ian,
Got your mail ok, Ill draw up the surround on autocad and get a price to you for Monday, what size fixing holes do you want.
Ive got some 3mm Ali in stock so can do right away, wont be expensive
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Many thanks
the_fbi
posted on 17/8/08 at 02:10 PM |
FYI - Its well worth installing eMachineshop from http://www.emachineshop.com.
(direct download http://www.emachineshop.com/ftp/emssetup153.exe )
Not only will this allow you to design parts, you can get them quoted, view them in 3D and export to a number of formats which can then be imported by
other people to CNC (waterjet, mill, etc) which reduces their time and hence your cost. + you get exactly what you designed not how somebody else
interpreted it.
I admit, unless you want a few hundred parts there's little point using their online ordering facility, but the cost feature is nice so you can
value engineer the part.
Its the perfect tool for knocking up this project, viewing it and exporting for somebody to make you one.
the_fbi
posted on 17/8/08 at 02:29 PM |
eg.
![](/galpreviews/gears.JPG) ![gear surround](/gallery/gears.JPG) gear surround
saigonij
posted on 17/8/08 at 02:49 PM |
WOW! that looks great!
My friend Bill has his gear lever in the same position, so i will need two.
AndyW7de - i was going to use some m6 button head bolts, so cani have the holes M6 please.
wow, this is great, thank you every body.
saigonij
posted on 17/8/08 at 02:50 PM |
and Andyw7de - can you do the concentric radii as indykid suggests?
( the reason they are the same is cause i knocked it up in word! )
cryoman1965
posted on 17/8/08 at 03:47 PM |
Contact rebelrider from this site. Good work and Price.
Nige
andyw7de
posted on 17/8/08 at 05:36 PM |
Holes and radii not a problem
matt_claydon
posted on 17/8/08 at 07:50 PM |
Would be interested to know your price for making these Andy - it would be a good guide as to what this kind of work costs.
saigonij
posted on 18/8/08 at 07:04 AM |
Cheers Andyw7de - i gave you my mob number in the email, so just let me know what the price is - im not always able to answer the phone at work so
just leave a message.
cheers for the help. :-)
andyw7de
posted on 18/8/08 at 08:34 AM |
Ok guys the drawing is done the costs are calculated
To cut the gear suround from 3mm Aluminium
£3.00 ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) inc postage
Obviosly still needs painting or polishing by your own fair hands
can also countersink the holes if required
cheers
saigonij
posted on 18/8/08 at 05:03 PM |
cheers mate, i got your email earlier. look forward to seeing the pictures this evening.
