phil T5
posted on 17/8/08 at 09:16 PM |
Tansmission tunnel snagging
The axle is hitting the bulkhead on my car whcih i can fix by raising the rideheight
However it also appears that the trammisson casing is fouling on the transmission tunnel on one side
Its actually a welded on bracket thats scrapping which holds an electrical cable that attaches to a threaded tube attaching to the trammisson
casing.
I can trim this bracket down to give more clearence but wondered what this is.
Is it the speedo attachment?
I will post photo when i have chance
twybrow
posted on 18/8/08 at 09:19 AM |
I thought I had the same issue - axle hitting bulkhead. When I adjusted the ride heigh etc to a reasonable amount, the clearance is ample. Get the
height sorted first, then look at your clearance issues....!
