New Topic New Reply
Author: Subject: ERW or CDS?
Jesus-Ninja
posted on 18/8/08 at 11:10 AM Reply With Quote
ERW or CDS?
As per the title...
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
Marcus
posted on 18/8/08 at 11:19 AM Reply With Quote
ERW
Marcus
Because kits are for girls!!
Jesus-Ninja
posted on 18/8/08 at 11:24 AM Reply With Quote
Originally posted by Marcus
ERW
because...?
posted on 18/8/08 at 11:27 AM Reply With Quote
...it's cheaper!
flak monkey
posted on 18/8/08 at 11:30 AM Reply With Quote
CDS is unnecessary for a chassis, and also not really a requirement for suspension parts either (with careful positioning of the seam).
Sera
http://www.motosera.com
Alan B
How can you ask someone to elaborate upon an answer to such a vague question?
Jesus-Ninja
posted on 18/8/08 at 11:35 AM Reply With Quote
Fair comment
It's been suggested to me that I should use CDS rather than ERW as it is significantly stronger for the same guage.
Strikes me that the chassis is the one thing you get one pop at, so it may pay dividends to go CDS.
Alan B
posted on 18/8/08 at 11:43 AM Reply With Quote
Fair comment
First of all CDS is NOT significantly stronger, and as Flak says used correctly ERW is fine for most applications.
Also, have you actually looked for and found CDS in square section?...not saying it's not made, but it is very rare and hard to find..I think I've only ever seen it in chromoly.....and so very expensive.
smart51
posted on 18/8/08 at 11:50 AM Reply With Quote
I've seen plenty of pictures of crashed kit cars. Never have I seen the seam of a tube split. Maybe it can happen but then aren't the tubes held to each other by weld?
I'd be tempted to use CDS if using thinner walled tube. The extra cost of making it might be offset by the lower material cost.
[Edited on 18-8-2008 by smart51]
Jesus-Ninja
posted on 18/8/08 at 11:51 AM Reply With Quote
Thanks guys! I'll leave my order for ERW as is then!
[Edited on 18/8/08 by Jesus-Ninja]
posted on 18/8/08 at 04:09 PM Reply With Quote
Where can you buy CDS in square section? I've only seen it in round and ERW in round, rectangular or square.
Jesus-Ninja
posted on 18/8/08 at 04:15 PM Reply With Quote
I dunno! I don't even know if the place I ordered it from does it. But I got a mail from a friend (who knows a thing or two)
If you can change that to CDS rather than ERW, I would if I were you. CDS is nearly twice as strong for the same size although it will be more expensive. I'm pretty sure that like for like the difference in strength is a factor of 1.8/1.9
Hence my questions
Still, sounds like ERW is fine. So I have a great pile of steel arriving tomorrow!
Rasteirinho
posted on 20/8/08 at 01:00 PM Reply With Quote
Sorry, but what ERW and CDS means?
'99 Mitsubishi Lancer Evo VI RS2
'85 Toyota Corolla GT TwinCam
Alan B
posted on 20/8/08 at 04:26 PM Reply With Quote
What a load of bollocks..
The question was a comparison of production method. CDS is NOT inherently any stronger ERW.
Now if you are comparing different metalurgical specs...that's a different story..but ERW and CDS of SAME material have very similar mechanical specs.
iank
posted on 20/8/08 at 04:35 PM Reply With Quote
ERW = Electrically Resistance Welded
CDS = Cold Drawn Seamless.
There is also DOM (Drawn over Mandrel) to add some more confusion.
It's the way the tube is made, ERW is made from a sheet which is folded and then welded so it has a noticeable seam where CDS is manufactured without a seam.
DOM is ERW that is then processed to smooth down the seam.
It's theoretically possible in a crash for a seam to split, but in reality, if your chassis is well designed, if it does you have a lot more to worry about as you'll already be dead from the shock loads of the massive deceleration you'll have been through.
Anonymous
rgdavid
posted on 2/1/09 at 07:14 PM Reply With Quote
specs for steel tube
good evening,
could someone please give me the materiel specs for ERW chassis making square tube, in BS or europeen or prefrably french standards (cos i live in france),
this would be a great help to find the equivalant here to order my tubes, thanks & happy new year!, david
alistairolsen
posted on 8/1/09 at 02:48 PM Reply With Quote
so cds isnt worthwhile for a chassis,how about for wishbones?
Hugh Paterson
posted on 8/1/09 at 06:35 PM Reply With Quote
Depends on who u ask (as always), IMHO CDS is "ideal" for wishbones, but I have also used ERW. If cost is not an issue, I would use CDS however and recommend its use to customers
Shug
alistairolsen
posted on 8/1/09 at 07:08 PM Reply With Quote
Shug
Id agree on it being the ideal solution, but since cost is always an issue except in F1 Im wondering what I can get away with without compromising safety!
I dont want to make any decisions that might cause injury to me or my passengers, but if I can safely halve the costs of my wishbones then I will!
Hugh Paterson
posted on 9/1/09 at 06:17 PM Reply With Quote
Hi Alistair, I would suggest for the cost of buying enough CDS to do your wishbones its a "no brainer" have u been given a quote?
Shug
rgdavid
posted on 14/1/09 at 04:20 PM Reply With Quote
Originally posted by rgdavid
good evening,
Bump , helpy help please, thanks, dave
[Edited on 14/1/09 by rgdavid]
posted on 14/1/09 at 09:05 PM Reply With Quote
It's just mild steel 25x25 with 1.5mm wall thickness Dave. Nothing special or exotic is needed. You might have to have 2mm wall but it isn't going to make that much difference overall.
rgdavid
posted on 15/1/09 at 12:40 PM Reply With Quote
thanks,
thanks a lot, but quite suprised its nothing special,
i use EN 10219 S-235JRH everyday for making gates etc, its nothing special at all !
trying to find a grade between that & 25cd4s
love your signiture !
all ze best, dave
New Topic New Reply
