Author: Subject: 16v redtop wiring
frankycopp
posted on 25/8/08 at 04:46 PM Reply With Quote
16v redtop wiring
how hard is the redtop to wire in? can you use original loom ecu etc? thanks
bill132hotrod
posted on 25/8/08 at 05:56 PM Reply With Quote
redtop wiring
I dont know how much difference there is but im running bike carbs and a dissy, and i had no problems at all, i ran the whole lot up on the bench first so it ain't that hard.
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
Paul TigerB6
posted on 25/8/08 at 07:30 PM Reply With Quote
I imagine you have seen the other threads on the XE but just in case you should have a look at this thread
linky to another old thread
You wont be using the original ECU / loom anyway unless you keep everything totally standard which is highly unlikely. Personally i'd look at the bike carbs / throttle bodies route with MegaJolt (for carbs) or MegaSquirt (for throttle bodies)
