Author: Subject: what socket?
bracey
posted on 31/8/08 at 06:28 PM Reply With Quote
what socket?
hi ,im wanting to remove bottom pully from xe engine .
book says torx female head!
what i have got are like multi splined female head??
is there such a bolt and what do they call it
cheers
richard
flak monkey
posted on 31/8/08 at 06:34 PM Reply With Quote
Do you want a torx socket or key?
Both are available in lots of different sizes.
Examples:
http://www.jesstools.co.uk/14pc-Female-Torx-Socket-Set_AJHR1.aspx
http://www.toolspot.co.uk/product/10pc-3-8indr-torx-bit-sockets-on-rail-double-blister
Sera
http://www.motosera.com
bracey
posted on 31/8/08 at 06:37 PM Reply With Quote
it would be the key neede but they are not torx they look to have loads of small grooves rather than a star shape?
MkIndy7
posted on 31/8/08 at 06:38 PM Reply With Quote
The Socket is called an E20 socket and that nut is STUOOOPIDLY Tight!
blakep82
posted on 31/8/08 at 06:39 PM Reply With Quote
if its standard, and similar to my later xev engine, it is a femal torx socket that you need.
[Edited on 31/8/08 by blakep82]
________________________
posted on 31/8/08 at 06:41 PM Reply With Quote
Torx --- the manual should give you the size, the correct size will be a really snug fit.
http://www.machinemart.co.uk/shop/product/details/cht144-40-pce-torxspline-bit-holder-s
[Edited on 31/8/08 by britishtrident]
bracey
posted on 31/8/08 at 06:49 PM Reply With Quote
there not torx ,
those xzn onlink look more like it
cheers
richard
Mark G
posted on 31/8/08 at 07:05 PM Reply With Quote
This is what ur after.
http://www.machinemart.co.uk/shop/product/details/pro44-14-pce-tx-bit-set/path/socket-sets-sockets-tool-sets
On a seperate note, I've been using a set of these for almost 5 years now and haven't broken one yet. (Mechanic by trade).
MkIndy7
posted on 31/8/08 at 07:36 PM Reply With Quote
Originally posted by bracey
there not torx ,
cheers
richard
Maybe you'd be better putting up a picture if you could, as everybody else seems to suggest there a E bit and i'm pretty certain there a E20 as I know how much of a pig they are to get off.
I'd hope yours is still in the car as I dropped my whole FWD front subframe out to work on my engine and trying to get the bolt undone was turing the engine over even with it in gear.
It takes some serious leverage (a snapon air wrench wasn't man enough!) to get this bolt undone and i'd suggest a can of freezer spray to use on the bolt as heat is not a good idea as it has a rubber section to the front pulley and spares are very hard to find.
Good luck!
bigrich
posted on 31/8/08 at 09:46 PM Reply With Quote
the 6 small bolts are number 8 multisplines IIRC, the centre bolt is an e20 torx.
bigrich
posted on 31/8/08 at 10:00 PM Reply With Quote
do the items in the middle of the box look like what you need Rescued attachment AK219.jpg
bracey
posted on 1/9/08 at 06:09 AM Reply With Quote
they do ,ill be getting some of them
posted on 1/9/08 at 04:22 PM Reply With Quote
Ribe sockets?
