cwollen
posted on 9/9/08 at 06:08 PM |
ford crossflow 1300
Have got a set of AE double valve springs which I intend to fitt. Have stripped head down and am now rebuilding. The problem is the valve stem oil
seal fouls the inner spring. I can fitt them as the inner spring will rest on top of the oil seal but when the engine is running i am sure that the
spring will distort the seal as it is soft plastic.
any help anyone please
thunderace
posted on 9/9/08 at 06:18 PM |
mine done the same but when i put the cap on they just cleared the seals.
clairetoo
posted on 9/9/08 at 07:26 PM |
Have the spring seats been machined for double springs - they need to be flat .
Its cuz I is blond , innit
Claire xx
Will weld for food......
UncleFista
posted on 9/9/08 at 08:16 PM |
I used A-series (mini) valve oil seals with my Kent engine with double valve springs. The standard ones wouldn't fit as you say
Tony Bond / UncleFista
