cryoman1965
posted on 25/9/08 at 04:04 PM |
2 LTR TDCI Mondeo 04 Using loads of water
As title says car is using 1-2 ltrs of water a week. There are no obvious signs of a leak. Any known faults with this engine.
Duratec?
N
mr henderson
posted on 25/9/08 at 04:30 PM |
Head gasket?
I trust you have not been tempted to top up with plain water, due to loosing the corrosion inhibitor from the coolant
John
flak monkey
posted on 25/9/08 at 04:53 PM |
It will, almost certainly be the water pump, only leaks when its running to start with. Our TDCi focus did the same thing
Sera
http://www.motosera.com
froggy
posted on 25/9/08 at 05:23 PM |
yep water pump and the two small hoses that come out of it go soft and can weep, common prob on the transits too
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
