theconrodkid
posted on 2/10/08 at 01:51 PM |
drill bit
anyone got a drill bit i can borrow,needs to be between 15 and 19mm with a shank of 13mm to fit my pillar drill...cheers peeps
who cares who wins
pass the pork pies
chrisg
posted on 2/10/08 at 02:08 PM |
I've got one John but you're a long way away from me!
If you cant get one I'll send it to you, or they sell em in machine mart, ask for Blacksmiths' drills.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
r1_pete
posted on 2/10/08 at 02:13 PM |
I've a set too, but much the same location as chrisg......
jabs
posted on 2/10/08 at 02:21 PM |
Try Axminster
http://www.axminster.co.uk/product-Armeg-Blacksmiths-Drills--Large-Drills-with-Reduced-Shanks-21885.htm
theconrodkid
posted on 2/10/08 at 03:02 PM |
£5 to drill 2 holes,i,d rather eat my ferret than do that (in best yorkshire accent) .
hopefully someone nearer will have one ,if not cheers peeps
who cares who wins
pass the pork pies
splitrivet
posted on 2/10/08 at 03:51 PM |
Now I know why they make 50 pence pieces the shape they are Conrod......So they can get em out of your hands with a set of 36" Stillsons.
Bob
James
posted on 2/10/08 at 05:03 PM |
Got a round file haven't you Conrod?
- Muhammad Ali
omega 24 v6
posted on 2/10/08 at 05:05 PM |
17mm holesaw??? will fit a drill chuck.
theconrodkid
posted on 2/10/08 at 06:11 PM |
the metal is 3 mm thick and life is so short so a drill is really the only way
who cares who wins
pass the pork pies
posted on 2/10/08 at 07:03 PM |
Blimey. I thought I was tight!!!!
r1 locost
posted on 2/10/08 at 07:28 PM |
i have one.But postage is about 3quid each way you do the sums
clairetoo
posted on 2/10/08 at 08:22 PM |
A hole saw will easily cut through 3mm steel - I do it all the time at work
Just go half way through from each side - or drill a small (3mm ?) hole at one edge of the `circle` - thats what I do when cutting holes in 12mm ally
Its cuz I is blond , innit
Claire xx
Will weld for food......
dave r
posted on 2/10/08 at 08:24 PM |
where are you ?
omega 24 v6
posted on 2/10/08 at 08:30 PM |
A hole saw will easily cut through 3mm steel - I do it all the time at work Just go half way through from each side - or drill a small (3mm ?) hole at
Exactly. Well said it should take about 2 minutes. I've cut 2 inch holesaw holes through a 12mm folded steel ( cold work hardened etc )drawbar
hitch on ERF's before ( Not in 2 mins though![](/images//smilies/bigsmile.gif) )
theconrodkid
posted on 3/10/08 at 06:33 AM |
i,m in london,ive devised a cunning plan to circumvent the need for said drill,thanks anyhow peeps
who cares who wins
pass the pork pies
James
posted on 3/10/08 at 12:02 PM |
Once you've got a 13mm hole, taking it to 15mm with a round or half-round file really is about 5minutes work!
James
- Muhammad Ali
