cryoman1965
posted on 20/10/08 at 06:03 PM |
Embarassed to Ask!
Tried to change the front N/S indicator bulb on my 1993 Mondeo today.
How the Hell do you do it?
Can't access through the bonnet or wheel arch. Don't want to take the headlight off if it ain't nessesary.
5 minute job!!!!!! right
Anyone know how. Got my MOT retest tomorrow.
Nige
phoenix70
posted on 20/10/08 at 06:08 PM |
if its anything like my Focus, you need to take the headlight out to change.
Should only be held in with a screw and a couple of clips though
Later
Scott
Paul (Notts)
posted on 20/10/08 at 06:48 PM |
My puma needs the front grill off then the headlight out to change a bulb.
Paul
turboben
posted on 20/10/08 at 07:40 PM |
I think there is two spring clips and the whole headlamp unit slides out - its an easy once you've done it type job!
posted on 20/10/08 at 07:58 PM |
Think that may be the later Mondeos . ???
Shadowcaster
posted on 20/10/08 at 08:00 PM |
Is this any help it would seem you are not alone.
http://codo.co.uk/wp/2006/02/26/how-difficult-can-it-be-to-change-a-bulb/
[Edited on 20/10/08 by Shadowcaster]
Cheers Rich
The Roadster Blog http://richshaynesroadster.blogspot.com/
It does not matter how slowly you go so long as you do not stop.
Confucius Chinese philosopher & reformer (551 BC - 479 BC)
cryoman1965
posted on 20/10/08 at 08:41 PM |
DONE IT!
You don't need to remove the Headlight unit.
There is a Torx bolt inside the the car just behind the headlight. Undo and the light falls out. Will attach images later.
Nige
