sforma
| posted on 24/10/08 at 11:06 AM |
Hayabusa and R1 engine - CO2 emissions grams/Km or grams/mile
Hello,
Anyone could help me on the CO2 emission number (grams/Km or grams/mile of CO2) for a Hayabusa and a R1 engine BEC?
Tiago
[Edited on 24/10/08 by sforma]
matt_claydon
| posted on 24/10/08 at 11:12 AM |
To my knowledge these tests are not carried out for motorcycles and so no figures are published. Even if they were, the numbers would mean nothing if
you were using the bike engine in a car as the CO2 emissions would change dramatically.
sforma
| posted on 24/10/08 at 11:25 AM |
I need the approximated level of CO2 and CO in grams/Km (or grams/mile), that both the engines above produce. Maybe you could give me some information
from normal SVA emissions control. I don’t need the exact number but a more or less value.
This CO2 information is very important, because in Portugal to make the import from UK the taxes that I need to pay are based on the engine size (1000
or 1300cc) and especially the amount of CO2 produced.
smart51
| posted on 24/10/08 at 11:26 AM |
None are officially published for motorcycles. You can get a rough idea by calculating it yourself.
A peugeot 107 1.0i emitts 109g of CO2 per km (plus almost 1g of other carbon emissions). It does 61.4 MPG officially. All of the carbon in the fuel
must come out of the exhaust pipe and more than 99% of it is CO2.
An R1 BEC( driven just as gently as the eugeot has to be to get its 61.4 MPG) will probably get something like 38 to 40 MPG. Its CO2 per km emissions
figure will then be around 165 to 175 g/km. Not that this figure is of any official use.
Edit to say: 99% of exhaust carbon is CO2 only if you have a Cat fitted and the fuelling is calibrated so that the Cat does its job properly. Older
carbed engines tuned a bit rich will make a few percent CO.
[Edited on 24-10-2008 by smart51]
sforma
| posted on 24/10/08 at 01:54 PM |
between 165 and 175 it isn't a big issue.
a 1000 cc R1 with 175 grams/Km CO2 pay´s +/- 1000 pounds. And maybe with a powercomander it could be decreased before the inspection.
matt_claydon
| posted on 24/10/08 at 03:39 PM |
What exactly is contained in the 'inspection' you talk of?
There is no way CO2 output in grammes/km can be measured without a chassis dyno, a trained driver, a drive-cycle computer and some very expensive gas
collection and weighing equipment.
CO2 output depends much more on vehicle mass, aerodynamics and gearing than it does on the specific engine you use.
nstrug
| posted on 24/10/08 at 03:46 PM |
Are you sure they measure CO2 at the inspection??? CO certainly, but measuring CO2 is hard and extremely expensive to do - certainly VOSA centres in
the UK don't have the kit to do it. It requires a rolling road running the standard EU cycle and volumetric analysis kit.
I don't see how a PowerCommander is going to change CO2. Well, in theory you could run very rich which would drastically reduce your CO2
emissions, but of course your CO and HC emissions would go through the roof.
As has been mentioned, there are no CO2/km figures available for motorcycles, and even if there was, the numbers are for the vehicle, not the engine -
to compare, a 3-series and an X5 can have exactly the same engine, but the X5 will have substantially higher CO2 (much heavier and crap aerodynamics).
Exactly the same happens when you take a bike engine and put it in a car.
Nick
sforma
| posted on 24/10/08 at 08:04 PM |
i need to confirm 100% sure about the CO2 and/or CO. I must search for the complete Portuguese legislation.
This afternoon i went to a Kawasaki dealer. i ask for the registration document and for a 2008 zx-10R the value of CO is 0,623 grams/Km.
nstrug
| posted on 24/10/08 at 08:10 PM |
Right, that is CO _not_ CO2. Please double check what it is they need to measure.
CO is the horribly poisonous one that causes death by asphyxia and brain damage, CO2 is the inert, non-toxic one that causes death by rising water
levels, drought and food shortages
Nick
road warrior
| posted on 25/10/08 at 01:01 PM |
Co2 for an 06 R1 in a MNR was 188 grams/km during an official rolling road emission test.
This was completly stock e.g. no power commander etc.
sforma
| posted on 25/10/08 at 08:15 PM |
During the road emission test where you using a cat in your MNR?
road warrior
| posted on 26/10/08 at 01:58 AM |
Yes but it was the bike cat so it is pretty small. A larger cat may have helped?
