indyian
posted on 24/10/08 at 07:44 PM |
zetec exhaust
hi all i was just after some advice on what exhaust to put on my indy when my 2.0 zetec is fitted i see some peaple have used standard r1 cans do they
not restrict the engine ?
the car has allready been sva d so not worried about noise
any sugestions on what and were to get would be apreciated
austin man
posted on 24/10/08 at 08:08 PM |
Bought mine from Martin Keean pretty free flowing and stainless they meet the noise requirements of most tracks.
SeaBass
posted on 24/10/08 at 08:16 PM |
I'm using a Westfield manifold with link pipe to a Caterham silencer... Works very well and not too loud.
All parts were purchased second hand for not very much. I also have a Carbon covered R1 can that I took apart. The flow is pretty poor on it as the
gas does two u turns inside the can through different chambers.
big_wasa
posted on 24/10/08 at 08:27 PM |
Mine is from a fisher fury
catman
posted on 24/10/08 at 08:48 PM |
i have a silvertop with 205 bhp and i'm using a standard R1 can so i think they are a great can!
[Edited on 24/10/08 by catman]
SeaBass
posted on 25/10/08 at 10:27 AM |
That's a healthy output... Tell us more about your setup.
Danozeman
posted on 25/10/08 at 11:26 AM |
MInes a fishury fury manifold the same as wasa's with a can made buy a fellow builder on here.
n/s/r
Sounds nice but i may have to put a different can on it for sva as its a bit loud.
Dan
catman
posted on 25/10/08 at 06:49 PM |
"That's a healthy output... Tell us more about your setup."
its a silver top bottom end standard apart from ARP bolts, stage two head, ported and polished etc. Kent FZ2002 cams. Dunnel ignition and webber
45's power is 207BHP @6850rpm when it hits the limiter could get another 10-15 HP out of it if i higher the limiter but i worry about the bottom
end as it has done an unknown mileage. it also gives a healthy 190lbs/ft @ 5500 rpm all the figures are from a tried and tested rolling road.
the car has the same power to weight ratio of a dodge viper so i am well happy
indyian
posted on 26/10/08 at 12:42 AM |
thanks for all the advice guys you been a great help
