mongrelwestie
posted on 26/10/08 at 07:46 PM |
can anyone tell me how to wire this switch
what do each of the points go to, i know its only four wires and ive googled it but cant find it?
![](/galpreviews/rsvawip_rear_view.jpg) ![switch rear](/gallery/rsvawip_rear_view.jpg) switch rear
![](/galpreviews/rsvawip_wiper.jpg) ![switch front](/gallery/rsvawip_wiper.jpg) switch front
mistergrumpy
posted on 26/10/08 at 08:00 PM |
At a guess are the middle 2 the +ve and -ve for illumination and the outer 2 the +ve and -ve for the switch
[Edited on 26/10/08 by mistergrumpy]
Paul (Notts)
posted on 26/10/08 at 08:03 PM |
This may help - from westfield world
http://westfield-world.com/durite.htm
Paul
click wiper switch tab at bottom
[Edited on 26/10/08 by Paul (Notts)]
mongrelwestie
not sure if thats right as its a 2 speed wiper switch
mongrelwestie
posted on 26/10/08 at 08:05 PM |
the one on westfield world looks different
Paul (Notts)
posted on 26/10/08 at 08:09 PM |
Earth connection at the side for internal light
pin 9 on the westsfielt one is often connected interanally to the internal light so may be missing on your type of switch
that leaves the other 4 pins.
Paul
ps Sorry about the typing but already on the beer.
Paul (Notts)
posted on 26/10/08 at 08:12 PM |
Have a play with a 9v battery and bulb or voltmeter to check which is witch.
mongrelwestie
posted on 26/10/08 at 08:13 PM |
unless nine is on the other side to the earth? maybe?
Paul (Notts)
posted on 26/10/08 at 08:21 PM |
did not spot the tab on each side..sounds right to me
grusks2
posted on 26/10/08 at 08:38 PM |
The 2 small tabs either side of the switch are for the illumination, the others are 12v feed, speed1, speed2 and park ( the park becomes live/links to
the 12v feed terminal when the switch is turned off)
if you can use a multi meter its easy to work out
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
mongrelwestie
posted on 26/10/08 at 08:39 PM |
so how do i link them together for the park or does the switch do that?
Paul TigerB6
posted on 26/10/08 at 09:20 PM |
Finally Grusks answered without guessing which doesnt really help. As said, the terminals are live, speed 1, speed 2 and park. Your loom should will
generally have 5 wires going to the wiper motor - the 4 above plus an earth.
Built too many aeroscreened cars to remember the colour codes now but light green is generally the live feed to the switch / wiper motor.
mongrelwestie
posted on 26/10/08 at 09:22 PM |
no i have all the wires sorted out, i have 4 wires for the switch and the 5 for the motor its just knowing were the 4 go to, i have them all labeled
but need to know what points to connect them to
grusks2
posted on 27/10/08 at 08:43 PM |
using a multi meter
put the switch to the off position - (2 of the terminals should be connected)
put the switch on speed 1 ( one of the terminals from the above test and a spare terminal should now be connected )
put the switch on speed 2 ( the same terminal from first test should be connected to the last spare terminal )
hope this makes sence.
if a remember right
pin 1 is live
pin 2 is speed 1
pin 3 is missing
pin 4 is speed 2
pin 5 is park wire
[Edited on 27/10/08 by grusks2]
