Author: Subject: How to curve 1600X500 sheet lengthways
PHULL
posted on 27/10/08 at 02:35 AM Reply With Quote
Hi there
I wam building a Monopin inspired single seat hillclimb special. powered by a honda vtr1000. my main hurdel at the moment is figuring out how I could bend a curve with a 186mm radius into a 1600 long by 500 long sheet of 1.2mm aluminium.
any advide would be great
maartenromijn
posted on 27/10/08 at 08:01 AM Reply With Quote
As per the book? If I remember correctly, they put a pipe (around 100mm diameter) on two stands, and just bend the ali around it.
I can think of numerous variations on this method. Around a fence-pole for example.
You can make a model to check if you have the correct radius.
BLOG: http://thunderroad-super7.blogspot.com/
John Bonnett
posted on 27/10/08 at 09:24 AM Reply With Quote
Good Morning, I think maartenromijn is absolutely right with his method if you don't have access to slip bending rolls. You can make a T dolly using steel tube of the correct diameter and tap the aluminium round using a wooden slapper or flipper evenly a bit at a time along its length.
You have not mentioned what grade of aluminium you are planning to use but I would suggest pure aluminium our grade 1050A being the easiest to form.
I'd be very interested to see some pictures as you progress with the project.
atb
John
Humbug
posted on 27/10/08 at 09:32 AM Reply With Quote
If you don't have bending tools, round a telegraph pole or something similar using ratchet straps should get you close
PHULL
posted on 27/10/08 at 09:10 PM Reply With Quote
cheers fellas
might try the power pole idea, being 1600 long it is
the progress is very slow, but I could post a few photos later
austin man
posted on 27/10/08 at 11:01 PM Reply With Quote
when I made my bonnet for my locost I created two wooden templates and formed the sheet around them this does allow you to peen the ends over giving some additional rigidity.
prior to doing thi I rooled the front edge by follding it over a 1 meter alluminium ruler giving a double skin this also helped the rigidity
