<<  1    2    3    4  >>
New Topic New Reply
Author: Subject: Composite chassis
ceebmoj
posted on 14/10/09 at 12:50 PM Reply With Quote
Composite chassis
This morning I saw a GTM on the way to work witch got me thinking about Composite chassis. Does any body have a link to the manufacture of a Composite chassis GTM or other. There was thread in the three wheal section a while back but I cant find that now.
djtom
posted on 14/10/09 at 01:15 PM Reply With Quote
Westfield made a composite chassis car a few years ago. FW400 I think it was called. 400kg but OMG expensive.
MakeEverything
posted on 14/10/09 at 01:35 PM Reply With Quote
Id rather like the idea of a monocoque carbon fibre chassis for my kit..... if i had the money!
Kindest Regards,
Richard.
ceebmoj
posted on 14/10/09 at 02:33 PM Reply With Quote
I guess that s what got me thinking the GTM is GRP so I assume it responsible to manufacture I will keep having a look for the GRP over fome trike chassy that is out there
Triggerhappy
posted on 14/10/09 at 03:11 PM Reply With Quote
Send your drawings to these guy´s
http://www.atrgroup.it/
They have some experience.
Im from Sweden, so im escused...The Muppet drummer for president!!
iank
posted on 14/10/09 at 04:45 PM Reply With Quote
Think this is the thread you're talking about
http://www.locostbuilders.co.uk/viewthread.php?tid=94561
The link to the trimagnum grp over foam approach is here
http://www.rqriley.com/frp-foam.htm
Note there is some chassis under there, more of a big subframe really.
smart51's cabin scooter uses this method of construction, but also has a chassis. Lots of good information in his posts and photos.
[Edited on 14/10/09 by iank]
Anonymous
ceebmoj
posted on 14/10/09 at 05:28 PM Reply With Quote
there was anothere 1 + 1 three wheeler that was all grp over foam with bonded in kevlar bulkheads
[Edited on 14/10/09 by ceebmoj]
clairetoo
posted on 14/10/09 at 06:08 PM Reply With Quote
Do you mean the TREV ? Linkydink
Its cuz I is blond , innit
Claire xx
Will weld for food......
ceebmoj
posted on 14/10/09 at 06:38 PM Reply With Quote
thanks alot that is exactly the one I was thinking about
StevieB
posted on 14/10/09 at 06:50 PM Reply With Quote
I've been reading about trev and have made some enquiries as to the cost for UK supply of the honeycomb grp material - no answer as yet.
What I have found though is this
Not sure if you'd get the strength, but if you gave it adequate skinning with carbon, kevlar or woven roving then a decent strength might be achievable.
I had also been considering how to vaccuum bag the a monocoque using resin infusion - not only neater but I feel it would be stronger as well because you'd have less risk of getting any air pockets trapped in there.
ceebmoj
posted on 14/10/09 at 07:33 PM Reply With Quote
nasty bob from the mid engen section
http://www.locostbuilders.co.uk/viewthread.php?tid=73075
has used a skined hunny come sections to pannel in parts of his chasy maby the product he used is apropreate
ceebmoj
posted on 14/10/09 at 07:39 PM Reply With Quote
also have you got any picture of how hard points are mounted to trev?
on old formula vauxall lotuses a hole is drilled and a aluum top hat inserted from both sides so tha you cant crush the center section.
StevieB
posted on 14/10/09 at 08:08 PM Reply With Quote
That's about it - ali bobbins and also in some placs a large ali spreader panel, as well as angle in the corners etc.
No details on Trev, but have a read of 'How to Build Motorcycle Engined Race Cars' and it hs some explanation, as well as Allan Staniforths 'Race and Rally Car Source Book'. The first book is OK - not much explanation of actually building a cr but a decent bit of starter info and plenty of ideas on how to do various things - it has a chapter on making a monocoque using honeycomb ali panels.
I have a distant plan to do something very similar but using the grp honeycomb/kevlar laminate along the same lines as Trev.
ceebmoj
posted on 15/10/09 at 07:33 AM Reply With Quote
as in this book?
http://www.amazon.co.uk/s/ref=nb_ss?url=search-alias%3Daps&field-keywords=How+to+Build+Motorcycle+Engined+Race+Car&x=0&y=0
StevieB
posted on 15/10/09 at 12:07 PM Reply With Quote
That's the one.
It's OK, but there again I picked up my copy for £6 (brand new) from an autojumble.
I also managed to get hold of an original, unopened copy of High Speed, Low Cost for £25 from the same guy
Theshed
posted on 15/10/09 at 02:37 PM Reply With Quote
My car is made out of honeycombe. A few bad pics in my folder. If I ever did it again I would make jigs and have inserts placed beteen the sheets and use laser cutting. I would also use solid bulkheads - or maybe just steel tube???
On the ther hand the locost shape might lend itself to 2 substantial side planks of honeycombe. I would go for 40mm 1/8" cell carbon/kevlar - no need to paint it either!!
I got my sheets from Aim Composites - they were good to deal with and were happy to make sheets up in Kevlar/carbon. They would have put in inserts. None of this was what you would call Lo Cost
StevieB
posted on 15/10/09 at 04:52 PM Reply With Quote
Right, just got my email quotation from Ayres (the company that does the stuff Trev is made from).
372 euros per sheet, which sounds quite a lot but by my figuring I reckon a single seater would be made from 3 sheets, so a monocoque single seater chassis for £1k (plus the cost of laminating in carbon/kevlar).
Probably need to price it up using cheaper materials because it'd be a bloody shame to make something that epxensive to fin a fundemental flaw in the design that needs changing (ie, a hole new chassi building).
Can you laminate ali panels with compsite materials successfully/strongly?
ceebmoj
posted on 15/10/09 at 05:52 PM Reply With Quote
what about the Nidaplast you posted about before it also come in a other thickness as well
[Edited on 15/10/09 by ceebmoj]
StevieB
posted on 15/10/09 at 06:00 PM Reply With Quote
I'm just not sure how string the nidaplast would be compared to ali honeycomb.
I might try an experiment by buying some and a small quantity of carbon, kevlar, carbon/kevlar and woven roving and see what works.
Theshed
posted on 15/10/09 at 09:09 PM Reply With Quote
I think that with care and preferably some heat you could get a decent bond between aluminium and Carbon/kevlar even in a diy situation. Just pay attention to joint design.
Volvorsport
posted on 16/10/09 at 06:54 PM Reply With Quote
www.darrian.co.uk
mosler are made from composite panels bonded together .
using this stuff .
www.teklam.com
my chassis has bonded in kevlar/carbon panels .
www.dbsmotorsport.co.uk
getting dirty under a bus
StevieB
posted on 16/10/09 at 07:53 PM Reply With Quote
But can you bond carbon/kevlar to ali panels to add strength. Not so much strength in the bending of the panel, but a whole ali monocoque laminated to unify the structure properly (if that makes sense?)
Volvorsport
posted on 16/10/09 at 09:25 PM Reply With Quote
in my opinion , bonding kevlar/carbon/grp to ali isnt really applicable in DIY situations since the need for temperature control and the surface preparation needed .
time has moved on , there maybe products/applications that would work , but, theres no reason to have carbon/kevlar bonded to ali since the composite is much better at doing it .
if you look at the teklam site , you can indeed get get honeycomb section with ali one side , carbon the other .
andkilde
posted on 16/10/09 at 09:43 PM Reply With Quote
You just want t be able to do this:
andkilde
posted on 16/10/09 at 10:46 PM Reply With Quote
Have you been following Denis Palatov's progress on the composite chassis for his DP1?
The pages on the composite chassis are in the "past" logs on www.dpcars.net
http://www.dpcars.net/dp1test/dj.htm
http://www.dpcars.net/dp1v8/da.htm
http://www.dpcars.net/dp1v8/db.htm
He's built his second prototype chassis using honeycomb and a thermoset adhesive.
Doesn't look particularly low cost, OK, doesn't look at all low cost but does look exceptionally well thought out.
t
<<  1    2    3    4  >>
New Topic New Reply
